Correct procedure to getting TDC? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2011, 06:04 AM   #1 (permalink)
View red13's Photo Gallery
Hi,
I have a 96 corolla 1.6L and I tried to replace the timing belt. I marked the positions of the gear and crank while the belt was still on, however when i released the the tensioner, the gear slipped and rotated out of the position. There was some slack on the timing belt, so that leads me to believe the belt had slipped one or two teeth. I'm confused as to how to set it back to TDC. Is this the correct procedure? Will this work?
1. Rotate the top gear until the markings with the letter K is on top.
2. Place a pencil in cyclinder # 1, manually crank the pulley until the pencil is at it's highest point
Thanks
red13 is offline   Reply With Quote
Old 11-12-2011, 08:52 PM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
I use a long phillips screwdriver. Turn the crank pulley until the "probe" in the spark plug hole is at the top. Make sure it doesnt get stuck sideways and jam in the plug threads. The align your cam gear and install the belt. Re-check it after you have tensioned the belt.
-SP
