Replacing Battery Terminals - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2011, 01:10 PM   #1 (permalink)
View MattJCraig's Photo Gallery
gen 7 Replacing Battery Terminals
The terminals that connect to the battery on my car have corroded and I need to replace them. I disconnected them from the battery; the negative side fell apart upon removal. Im seeking some advice on the steps i need to take to replace them. Do I clip the wires? Use a hack saw?
I don't think I can pry the old clamps apart because it looks like they have fused due to the corrosion.
Any help is greatly appreciated.
Thanks!
MattJCraig is offline   Reply With Quote
Old 11-19-2011, 04:46 PM   #2 (permalink)
I got it working. i just snipped the corroded terminal and clamped it with the new connector. cleaned it all up and its working now.
Old 11-20-2011, 11:45 AM   #3 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Those bolt on connectors arent very good and fail quickly. You also have internal corrosion in the wire that happens over the years. For best reliability you should replace the OEM wires with ones that have the ends already attached.
-SP
Tags
replace, terminal
