LED Dome Bulb Won't Work - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-19-2011, 08:51 PM   #1 (permalink)
dosbirn's Avatar
View dosbirn's Photo Gallery
Question LED Dome Bulb Won't Work
I just bought an LED bulb from Autozone to replace the original dome light bulb in my 1995 Corolla because it's too dim.
I just tried the LED and it will not light. The original bulb still works fine.
Is it possible this is simply a bad LED? Or could it be that it won't work without adding a resistor? I searched this forum and it seems that others have switched to an LED for the dome light with no problems.
dosbirn is offline   Reply With Quote
Old 11-19-2011, 10:10 PM   #2 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291352
View gold94corolla's Photo Gallery
Try turning it around and inserting it the other way.
gold94corolla is online now   Reply With Quote
The Following User Says Thank You to gold94corolla For This Useful Post:
dosbirn (11-19-2011)
Old 11-19-2011, 10:47 PM   #3 (permalink)
dosbirn's Avatar
Okay - I never would have thought the way you insert an LED would make a difference (especially since both ends are identical).
So, I went out to try it and after dropping the tiny booger twice (using a flashlight, mind you) and spending several minutes looking for it each time, I finally inserted it properly and YES, IT WORKS!
Problem is, not only is not NOT brighter, it changes colors! Who the heck would want their dome light to do that???
And the package says "BRIGHTER"??? I don't think so. Well, back to Autozone tomorrow to return it. I think it was the only type they carry for my 3175 original. Guess I'll need to order one online.
Thank you for your help and fast response, Christopher!
Old 11-20-2011, 11:36 AM   #4 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
http://www.ebay.com/itm/Light-Panel-...item35b66798c1
get one like that, the seller has others of different dimensions so measure first to see what will fit. They are BRIGHT.
Bitter is online now   Reply With Quote
The Following User Says Thank You to Bitter For This Useful Post:
dosbirn (11-22-2011)
Old 11-20-2011, 06:25 PM   #5 (permalink)
dosbirn's Avatar
Hmmm.... Well, it definitely looks very interesting and I'm sure it's very bright too! I'm afraid since I had trouble installing a simple LED bulb, (just like the original), this might be a little difficult for me.
Does it require rewiring the dome light? If so, I'm not sure I should attempt that. Sorry, these LEDs are very new to me.
Old 11-20-2011, 07:26 PM   #6 (permalink)
Yeah, any LEDs you get locally at Auto Zone or Pep Boys or Advance Auto is trash. Even Ebay is better because you have a wide selection and waaay cheaper price.
You should get the dome lights with those tiny LEDs on it, like bitter posted. They are plug and play, as you can see the multiple bases in the pictures. Just use the one that connects!
Old 11-20-2011, 08:07 PM   #7 (permalink)
dosbirn's Avatar
But the Ebay link Bitter posted has this description: Light Panel 48 SMD LED+Interior Bulb+T10+BA9S Adapter. I don't understand how to make this panel work in place of my bulb.
I am looking at this LED at Amazon: 31mm Festoon 12 LEDs SMD LED Bulb White for 3022, DE3022, 3175, DE3175. Two for $13.89. It looks like it would work. And the reviews were good.
What do you think?
Old 11-21-2011, 07:15 PM   #8 (permalink)
Bitter's Avatar
one of the adapters will fit where the bulb fit, plug it into the panel, put the plastic cover back on.
Old 11-21-2011, 09:15 PM   #9 (permalink)
Gameroom cash: $323345
View cipher93's Photo Gallery
LEDs are polarized, meaning the current has to flow a certain way for them to work (since they are diodes after all). I just used a blue xenon one from Pepboys in my Corolla it gave off a whitish light that complimented the blue interior nicely with some improvement in brightness, but an LED like bitter linked will be even brighter and cost less.
cipher93 is online now   Reply With Quote
The Following User Says Thank You to cipher93 For This Useful Post:
Old 11-22-2011, 08:57 PM   #10 (permalink)
dosbirn's Avatar
Thank you all for the great info. I'm definitely going to check out the eBay link Bitter provided again. I'll let you know if I have any problems!
Old 11-22-2011, 10:37 PM   #11 (permalink)
View Woz2000's Photo Gallery
Have people actually used these How's the lifespan? I bought a 13 LED USB light and the leds were burning out at the tune of 1 every couple hours of use.
Woz2000 is offline   Reply With Quote
Old 11-23-2011, 07:24 AM   #12 (permalink)
Bitter's Avatar
I've been using them in two of my own cars for over a year now with no issues, my Mom has been using 2 of the smaller ones in the front of her Mazda3 for about 6 months now as well without issue.
I've had my dome lights on for extended periods of time, 1/2 hour at a time more than once. They draw very little power and create almost no heat so leaving the dome light on for long periods causes no problems. Not to mention, they're so cheap that if you get a bad one or one burns out just buy another for $3. Heck, buy two now so you have a spare.
Old 11-23-2011, 08:04 PM   #13 (permalink)
dosbirn's Avatar
I agree - you can't beat the price so I ordered 2 also, one for the Corolla and the other for our 1997 Mazda Protege.
Thank you again for the suggestion, Bitter!
Old 11-23-2011, 08:52 PM   #14 (permalink)
Bitter's Avatar
Good deal, I've bought a few dozen things from them over a couple years. Shipping takes about a week, they're good to respond to questions too. They offer other sizes and styles, the regular LED kind is brighter by about 20-30 Lumen, but it's also thicker and may not fit in some cars. Visibly the difference is nothing I can see unless they're side by side. The smaller sizes may fit better in cars with smaller dome lights or with map lights. You could cut the wires off the adapters and use them for foot well lighting cheaply as well since they are adhesive backed.
Old 12-13-2011, 07:34 PM   #15 (permalink)
dosbirn's Avatar
I finally got the LEDs after 3 weeks - I guess it took long because they came from Hong Kong plus the holiday season. No big deal.
And they look AWESOME!!!! I installed them as soon as I got home. I used my own self-stick velcro pieces because I didn't realize they were adhesive backed until I reread your post just now but they fit fine.
My husband says now he wants one for his 2008 Ford F150!
Thank you again for the great suggestion, Bitter!
