Crankshaft Pulley Bolt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-07-2011, 01:37 PM   #1 (permalink)
Only Drive if I have to
Yodadex's Avatar
View Yodadex's Photo Gallery
What size socket do I need for the 1.8L crankshaft pulley bolt? 19mm? I bought a 3/4" impact wrench and I wanted to buy airtool sockets instead of damaging my regular sockets.
Thanks
Stephen
may i help you?
Yodadex is offline   Reply With Quote
Old 12-07-2011, 01:46 PM   #2 (permalink)
nitronate33's Avatar
View nitronate33's Photo Gallery
you can get a full set of stanley impact sockets at wal-mart for like $20-$25. it will certainly have the size you need.
2005 Toyota Solara SE 2.4L
2004 Subaru Impreza WRX 2.0L
2011 Ford Mustang Shelby GT500 5.4L
nitronate33 is offline   Reply With Quote
Old 12-07-2011, 02:52 PM   #3 (permalink)
Yodadex's Avatar
The problem is my impact wrench is a 3/4" fit. The socket sets for 3/4" are a bit more expensive. I guess what I can do is lift the car and take the wheel off and see what size it is. I was hoping someone here knew the size off of top of their head.
Harbor Freight sells individual sockets. I rather spend 4 bucks on a single socket than buy a 60 dollar set.
Stephen
may i help you?
Old 12-07-2011, 03:01 PM   #4 (permalink)
View Woz2000's Photo Gallery
It is 17mm.
The DIY has a lot of info...
DIY Timing belt and water pump replacement Corolla 93-97
Thanks
Woz2000 is offline   Reply With Quote
The Following User Says Thank You to Woz2000 For This Useful Post:
Yodadex (12-07-2011)
Old 12-07-2011, 03:03 PM   #5 (permalink)
View yota_rolla_dude's Photo Gallery
gen 7
I actually just replaced that pulley and it's a 21mm bolt that holds it on
yota_rolla_dude is offline   Reply With Quote
Old 12-07-2011, 03:03 PM   #6 (permalink)
Yodadex's Avatar
awesome thanks
Stephen
may i help you?
Old 12-07-2011, 03:04 PM   #7 (permalink)
Yodadex's Avatar
dang I better physically check before I order something online.
Stephen
may i help you?
Old 12-07-2011, 05:28 PM   #8 (permalink)
I did mine and it was 17mm, the DIY says its 17mm and no one has complained about it, so I'm fairly certain it is 17mm from the factory.
Could you be mistaken or the 21mm was a replacement?
Old 12-08-2011, 05:51 PM   #9 (permalink)
View ratman90's Photo Gallery
OK so I found you gus today because the crankshaft pulley came off of mine today. 1993 corolla has an "A" in the 4th digit of VIN. What does the bolt look like? I can not see any threaded area on the nose of my crankshaft. About half an inch in, I can feel a smooth flat area. It feels machined. It does not feel like a broke off bolt is remaining in there. But I wonder how long the shoulder is on the bolt and is this really the bolt broke off in there where the threads start?
ratman90 is offline   Reply With Quote
Old 12-08-2011, 07:17 PM   #10 (permalink)
Ok so i guess there should also be a harmonic balancer as well? I guess that came off as well ? The lower part of the timing chain cover is still on over the crank. Is the balancer behind the cover? And i do not see that the crank nose is slotted for a key. I am so lost here. Any ideas?
Old 12-08-2011, 11:48 PM   #11 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
You sound way-over-your-head lost. Since you appear to not even know what parts should be there you should have someone who knows engines work on your car.
-SP
