aftermarket stereo wiring question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-10-2011, 07:10 PM   #1 (permalink)
Gameroom cash: $117200
View newtoyota's Photo Gallery
I bought an after market stereo, but for illumination it only has one orange/white wire coming out of it. The corolla harness has only an orange wire coming out of it.
Is the orange/white supposed to connect to the orange on the corolla harness?
newtoyota is online now   Reply With Quote
Old 12-10-2011, 08:15 PM   #2 (permalink)
The Tri-Camry Family
Yuko's Avatar
Gameroom cash: $260240
View Yuko's Photo Gallery
An orange wire with a white stripe should be for the dimmer while a solid orange wire is for illumination. (That's the standard color code) Is the orange wire on the Corolla harness one of those adapter or are you referring to the factory wiring? Because I don't recall Toyota using Orange in their audio wiring. Check the factory wiring and it should run from green (Toyota's color for illumination) to solid orange on the headunit.
"Yūko" 2001 Camry 5S-FE/A140E @ 92k
"Sandy" 2002 Camry 2AZ-FE/U241E @ 158k
"Chihaya" 2012 Camry 2AR-FE/U760E @ 6K
Yuko is offline   Reply With Quote
Old 12-10-2011, 09:07 PM   #3 (permalink)
yeah that's the standard that's why I am confused.
here's the harness i have: http://www.ebay.ca/itm/390368359837?...ht_4281wt_1344
in the stereo's (DEH P4000UB) installation guide: it says to connect it's orange/white wire to the "lighting switch terminal"
http://www.pioneerelectronics.com/St...Manual1019.pdf
Old 12-10-2011, 10:55 PM   #4 (permalink)
View Woz2000's Photo Gallery
Since both wires are positive supply voltage lines, it won't hurt to just hook them up and see what happens. Alternatively, you can use a voltmeter to check the voltage on the wire coming from the car (how it behaves).
Woz2000 is offline   Reply With Quote
Old 12-10-2011, 11:16 PM   #5 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
get the METRA installation harness kit, match the colors, voila!
Ah, I see you have the harness. Yes, illum to illum, org to org/wht
Bitter is online now   Reply With Quote
