Have you ever had a problem with the starter? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-12-2011, 07:04 AM   #1 (permalink)
YOGI.CR's Avatar
View YOGI.CR's Photo Gallery
Hello buddies!
I am a little bit curious. I just got a problem with the starter and I already got it fixed. I was told that this is kind of a "known issue" on Toyota´s but before I say any word I want to hear you all first!
YOGI.CR is offline   Reply With Quote
Old 12-12-2011, 08:47 AM   #2 (permalink)
View Woz2000's Photo Gallery
IIRC, according to Identifix, the 94-96 Corolla has a higher failure rate on the starting and charging systems.
Originally Posted by YOGI.CR View Post
Hello buddies!
Woz2000 is offline   Reply With Quote
Old 12-12-2011, 04:28 PM   #3 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
just WHAT is the "known issue" with starters?
-SP
Old 12-12-2011, 07:25 PM   #4 (permalink)
pdq
Gameroom cash: $220900
View pdq's Photo Gallery
Denso starters are some of the most reliable starters in the world.
However, after approximately 100k miles (and tens of thousands of starts), the copper contacts in the solenoid get worn down and need to be replaced. You can buy a replacement contact kit for under $20 to refurbish the starter to virtually brand new.
pdq is offline   Reply With Quote
Old 12-12-2011, 08:30 PM   #5 (permalink)
wei
wei's Avatar
View wei's Photo Gallery
Started having problems with the starter clicking but not fully engaging. I bought a new set of contacts but when i went to refurbish the starter all I did was clean and put the contacts back in. Works fine now.
1997 Corolla CE - Sold as of 2/2012
2009 Corolla LE
2008 Mazda B2300
wei is offline   Reply With Quote
Old 12-12-2011, 08:58 PM   #6 (permalink)
You asked for it...
View azcorolla's Photo Gallery
X2. It's almost always the contacts, and it is pretty common, probably because they are geting pretty old now.
Cheap to fix if you do it yourself. Several threads on here about it.
azcorolla is offline   Reply With Quote
Old 12-13-2011, 06:21 PM   #7 (permalink)
Andele, andele!
speedy25's Avatar
And that problem is common to ALL starters that use that engineeering. It works well but of course things wear over time. Wei found out that some cleanup can fix the problem but many times one contact will be so eroded away it has to be replaced.
-SP
Old 12-14-2011, 09:05 PM   #8 (permalink)
View mouse2426's Photo Gallery
my engine cranks slowly even after i replaced the battery .. i am going to do a circuit test on the starter next...
mouse2426 is offline   Reply With Quote
Old 12-15-2011, 05:06 PM   #9 (permalink)
TIEyota fighter ace
Piloter's Avatar
Gameroom cash: $142700
View Piloter's Photo Gallery
Something got stuck in my Denso a few years back where it wouldn't stop trying to start. Probably about 180K or so but that's a very rough guess.
WIP AE102.
Piloter is offline   Reply With Quote
Old 12-15-2011, 06:27 PM   #10 (permalink)
You asked for it...
I think it's a good possibility that the problem for both Piloter and Mouse is still the solenoid
Mouse - high resistance or poor electrical contact, caused by worn contacts.
Pilot - stuck solenoid.
