The left is closer to Master Cylinder so it will bleed faster than right. Less resistance.
It's a two man job.
If you don't want a mess, attach a 1/4" hose to bleeder into a water bottle with 1" of brake fluid, submerge hose in clean fluid.
Have someone pump brake pedal 5 times and Hold pedal, open bleeder valve, person inside rides pedal to floor, close bleeder. Repeat 3-5 times, until no air bubbles appear.
Do front first, then rear. Keep an eye on Master Cylinder do not let it go empty.
