95 corolla won't start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-18-2011, 09:19 PM   #1 (permalink)
View team_lunatics's Photo Gallery
i have a 95 corolla dx. it has the 7afe motor in it. i replace the headgasket job and install new waterpump, timing belt, and all gaskets. i know forsure i did the timing correct. assemble everything back together and started the car. it turned over the first two trys, but then now it will just click from the starter. on my cluster, the battery and oil light wont go away when i turn the key to the on position. i know the starter and battery is good, cause it did work before i did the headgasket changover. anyone with any suggestions will be very appreciated. thanks.
team_lunatics is offline   Reply With Quote
Old 12-19-2011, 05:39 AM   #2 (permalink)
Nick
Gameroom cash: $155900
View TheNightWolf's Photo Gallery
Battery light is on when the ignition is on because its not sensing power from the alternator.
And oil light is because there is no oil pressure.
It sounds like your battery could be dead.
Charge it, over night on a low setting and try in the morning.
-1994 Toyota Corolla-Ksport Coilovers, custom exhaust, Weapon R intake with Ram Air Kit
TheNightWolf is online now   Reply With Quote
Old 12-19-2011, 09:47 AM   #3 (permalink)
thanks. will try it and see what happens. thanks for the suggestions.
Old 12-19-2011, 01:39 PM   #4 (permalink)
it was a weak battery. omg, i didn't know a battery would be the problem. thanks to all who looked at this thread and thanks for the suggestion.
Old 12-19-2011, 02:05 PM   #5 (permalink)
Nick
Clicking is usually a sign of a bad battery, and if your in Northern US its cold as balls out, so typically batteries go to crap now.
Old 12-21-2011, 02:28 PM   #6 (permalink)
well fellas,
i thought the problem was fixed, but its starting to do the same thing. i replaced the battery with a known good battery and it did start up. my girlfriend drove the car to work that same day and it didn't die or anything. it started right back up when she came home from work. i went out the next morning to start it back up, it wouldn't. it just clicks from the starter. i would try like maybe 25-30 trys to crank the motor and it would just click from the starter, then it would fire up. so i haven't drove it since. i don't want to get stranded somewhere. this is what i know as of right now - good battery (replace with my running honda accord battery), good starter (got it tested at advance auto parts, tested good), good motor (its not seized, because my girlfriend drove it to work and back with no problem), im pretty sure my connections on the battery are good and clean. my only other option is my starter relay. imma test the starter relay and see if it works. if anyone else has any other suggestions, i would highly appreciated it. thanks.
Old 12-21-2011, 06:05 PM   #7 (permalink)
Nick
Test the alternator before you go though all the tough stuff.
Simple things are usually the cause to cars problems.
Old 12-21-2011, 06:09 PM   #8 (permalink)
yeah imma do that after i test the starter relay. i will let you know what happens. thanks.
Old 12-21-2011, 06:16 PM   #9 (permalink)
mobiless2's Avatar
View mobiless2's Photo Gallery
Sounds like bad brushes on starter.
mobiless2 is offline   Reply With Quote
Old 12-21-2011, 06:45 PM   #10 (permalink)
i had the starter tested at advance auto parts, the guy confirms it's good. everything was working before i did the headgasket changeover. idk why it's like that now. maybe a ground or something?
Old 12-22-2011, 01:29 PM   #11 (permalink)
View 96coroll's Photo Gallery
Test your battery as well. Maybe over night something was left on or something is draining it.
96coroll is offline   Reply With Quote
Old 12-22-2011, 04:13 PM   #12 (permalink)
starter relay is good. has 75 ohms on both power point 1 and 2. Next imma test the alternator. i hope it's something simple and dumb. anymore suggestions is appreciated. thanks.
Old 12-22-2011, 04:14 PM   #13 (permalink)
the corolla also has an anti-theft system also. how do you reset this? it might be this? idk?
Old 12-22-2011, 04:15 PM   #14 (permalink)
i replaced it with a good battery, still doing the same thing.
Old 12-22-2011, 06:32 PM   #15 (permalink)
Nick
Parasitic drain.
Is anything staying on after you turn the car off?
