need to diagnose a bad engine rattle(Video inside) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2011, 09:15 PM   #1 (permalink)
Gameroom cash: $117200
View newtoyota's Photo Gallery
I haven't taken the belt or done anything, the rattle started like a couple month ago but was barely noticeable. Now it's just too loud and need to deal with it.
http://imageshack.us/clip/my-videos/210/co7.mp4/
what does it sound like to you? spun bearing? massive exhaust leak ?
it's a little similar to this one, but stays with rev's....
4AFE 1.6 making a weird noise
if anyone had this rattle before and found out what it was please post !
Last edited by newtoyota; 12-19-2011 at 09:17 PM. Reason: sorry just noticed the video is upside down...
newtoyota is online now   Reply With Quote
Old 12-19-2011, 10:44 PM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
It should make you happy that I cant ear any rod knock. You'll know it when you get an engine with it!
Like in the other link.. What is the condition of your engine mounts?
-SP
Old 12-19-2011, 10:47 PM   #3 (permalink)
that's a relief, that i won't need a new engine.
But I can't live with that sound, i barely step on the gas it sounds like something will fall apart (like in the video.)
engine mounts are not too bad(not much shaking), and how would they make a noise like that anyways?
Old 12-20-2011, 07:49 AM   #4 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
Broken flex pipe/cracked manifold/large exhaust leak.
Bitter is online now   Reply With Quote
Old 12-20-2011, 09:14 PM   #5 (permalink)
alright so will start by checking the exhaust system, any other suggestions what might be causing it ?
can any internal engine parts make a sound like that ? (stuck valve..etc?) because it sounds like its coming straight out of the engine itself.
Old 12-21-2011, 10:06 PM   #6 (permalink)
Andele, andele!
speedy25's Avatar
It sounds like it but the engine mounts need to be removed and inspected. Just looking at them you cant really tell. Remove them and it becomes very obvious.
-SP
Old 12-22-2011, 09:46 AM   #7 (permalink)
update: so the flex pipe was broken and got it fixed today. Thanks Bitter.
however that was only a part of the rattle, there is still a rattle, here is a video with a leak-less exhaust system:
http://imageshack.us/clip/my-videos/641/u6gr.mp4/
Old 12-22-2011, 12:47 PM   #8 (permalink)
View Corolla Sound's Photo Gallery
It very well may be the valves. I had a similar issue (engine making chugging noise and vibrating violently (worse then yours)) and it turned out to be a blown head gasket and I had to recondition my valves and cylinder head. It also turned out that I lost compression in 3 of my cylinders which most likely caused the violent vibration. Still dont know how I blew my head gasket from 2 small revs under 5000 rpm each. Just my luck
Corolla Sound is offline   Reply With Quote
Old 12-22-2011, 07:22 PM   #9 (permalink)
Bitter's Avatar
Honestly, I'm not hearing it.
Old 12-23-2011, 08:40 PM   #10 (permalink)
here is a better video:
http://imageshack.us/clip/my-videos/263/7ot.mp4/
not sure if it's normal, let me know what you guys think
Old 12-23-2011, 09:03 PM   #11 (permalink)
Bitter's Avatar
I still can't hear anything other than an engine revving, try with the camera below the engine?
Old 12-27-2011, 09:17 PM   #12 (permalink)
corolla 95
moschinoespin's Avatar
View moschinoespin's Photo Gallery
Originally Posted by bitter View Post
broken flex pipe/cracked manifold/large exhaust leak.
this ^^^^^^ i guess header
moschinoespin is offline   Reply With Quote
