Alrighty so with the warm weather here my shifting really started getting notchy/clunky. Not grinding but it didn't feel like I was cutting through butter anymore. And the car would actually shift better cold than warm!
So I started looking back into fluids for the tranny. I was VERY VERY tempted to put in g060 VW OEM oil. It is a gl4 oil but the viscosity is mystery. And most likely is around 6.4 cst @ 100c versus the 13-15 cst @ 100c it should be. G050 VW oil was a true 75w-90 but this oil is no longer made and it seems VW has moved to lighter oils in the fight for highest mpg claims in the car sales world. ANYWAYS!
Our trannies can use gl4 or gl5, but after extensive reading it seems that gl4 synthetic or good ol Dino oil provides the best shifting for these cars. And if you are going to get gl-5 make sure it has NO LSD additives and it should also be fine.
Red Line was my first pick but after extensive reading I decided it might not be the best oil. Something about bearing failures and that red line isn't really a certified oil (API, ACEA etc). That was enough for me to stay clear.
As for BG synchroshift II I can't get it locally and it is apparently a lighter weight oil so I also didn't bother with that either.
So all I could really find in gl4 was pennzoil synthetic 75w-90. It wasn't really cheap either at 17$ per bottle. But it should last at LEAST another 30k so I don't mind paying the bit extra. Shifting is back to being smooth and normal (as expected with putting in any sort of new fluid). The old fluid after 30K was a dark honey brown so it was due for the change.
As for this new fluid only time will tell how it holds up. But I can say without a doubt that this fluid will make your MT happy and you won't have shifting issues after putting it in. MPG status TBA...
Cheers
