bad wheel bearings - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-26-2011, 02:59 PM   #1 (permalink)
View tommyguns's Photo Gallery
bad wheel bearings
i have a 95 corolla about 184k on there and it has bad wheel bearings. i was wondering what if anything could go wrong if i keep driving like this until i can get money to fix it. Thanks to all.
tommyguns is offline   Reply With Quote
Old 12-26-2011, 03:22 PM   #2 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
eventually the bearing will sieze up. This can cause damage to the hub. Possibly get hot enough and cause damage to other things like melting any nearby rubber or plastic (Wheel Seals, ABS sensor if equipped, CV Boot, Ball Joint). But if you wait to long, you will cause damage to the spindle and possibly the hub costing you more in the long run. Get it fixed asap!
The bearing and seals are not much money...$30-$40 and is medium difficulty to replace and if u have access to a hyd press.
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
Old 12-26-2011, 04:46 PM   #3 (permalink)
can i just buy the whole hub so i dont have to use a press ?
Old 12-26-2011, 05:35 PM   #4 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
Not really, maybe used but then you're back in the same position again very shortly and that would cost alot more.
Bitter is online now   Reply With Quote
Old 12-30-2011, 02:45 PM   #5 (permalink)
pdq
Gameroom cash: $220900
View pdq's Photo Gallery
Tommy, if you remove your hub assembly, you can take it to any shop with a hydraulic press, and they will press out the old bearing and press in a new one for probably 40 bucks.
The only hard part is removing the axle nut, and tie rod.
pdq is offline   Reply With Quote
