Car scraping on ground - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2012, 05:17 PM   #1 (permalink)
wei
wei's Avatar
View wei's Photo Gallery
Thumbs down Car scraping on ground
Recently my car has been scraping the ground a lot. Houston's roads are really bumpy, so whenever I cross an intersection or go over a manhole the car has a tendency to scrape. I went under and had a look today and it seems like the transmission pan is the lowest point.
This all started happening a few weeks ago after someone hit my car on the front fender and from what I conclude bent the subframe slightly. Coupled with old struts and basically any slight bump causes scraping.
Has this happened to anyone else before? I plan on changing the struts and springs as soon as feasible.
EDIT: I'm going out later to measure the height between ground and pan. Apparently 6'' is standard? Or so I've read. Will report back.
EDIT 2: 5-6'' between transmission pan and level ground. It's dark out so I didn't get an accurate read. Seems within spec. I'm becoming increasingly convinced that it's just my struts that have finally gone.
1997 Corolla CE - Sold as of 2/2012
2009 Corolla LE
2008 Mazda B2300
wei is offline   Reply With Quote
Old 01-01-2012, 09:53 PM   #2 (permalink)
pdq
Gameroom cash: $220900
View pdq's Photo Gallery
The springs hold your car up. How much clearance do you get between the top of each tire and the fender?
I replaced my 2 rear springs/shocks to fix scraping if I had 2 or more people in the back of my car.
pdq is offline   Reply With Quote
Old 01-02-2012, 01:17 AM   #3 (permalink)
Innovate or Die
MirrorEyes's Avatar
Gameroom cash: $152700
View MirrorEyes's Photo Gallery
Check your struts to see if they are wet. Push on your rear fenders and see if you hear a noise coming from the shocks. If so, it's probably the struts. If you hear no noise, but it is bouncy/noticeably sitting low, then it is probably your springs.
Checkout my CarDomain page.
MirrorEyes is offline   Reply With Quote
Old 01-02-2012, 05:23 AM   #4 (permalink)
Nick
Gameroom cash: $155900
View TheNightWolf's Photo Gallery
I scrape if my girlfriends overweight friend is in the back seat, I'd suggest new springs they're probably worn out and sagging.
And while your at it, get new struts if you know those are old too,
-1994 Toyota Corolla-Ksport Coilovers, custom exhaust, Weapon R intake with Ram Air Kit
TheNightWolf is online now   Reply With Quote
Old 01-02-2012, 04:34 PM   #5 (permalink)
View Danny289's Photo Gallery
Pay attention to this part (t cross) for any bent and missing bolts . check your mounts front and back for missing bolts. If somthing wrong, probably you can fix it yourself with combination of floor and bottle jacks and few stands(assume your mounts are ok) . Then consider your shocks and struts which as you mentioned they are old and it is good to be replaced .
I drove my car for 5 years after my mechanic warrned me about struts(stupied I know). I never had "scraping on ground" problem.
Danny289 is offline   Reply With Quote
Old 01-02-2012, 05:55 PM   #6 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
you sure your exhaust hasn't fallen down and is scraping? Plastic under panel loose and flopping around in the wind?
Bitter is online now   Reply With Quote
