Originally Posted by speedy25
What exactly failed? Usually they only die when the wires are damaged.
-SP
The first time it failed the CEL came on.Advance auto scanned the code-cam sensor fail.The 96 does not have a cam sensor;everything is run by the crank sensor.Prior to the CEL coming on it would be hard to start,lag,continue to turn over until it started,or the starter would just make a "thunk" noise.Well,same thing happened again this time,just about a year later.We changed the crank sensor and everything is back to normal.
