Bosch 12102 is the upstream California O2 sensor. $32 from RockAuto.com
Bosch 12201 is the upstream 49 state O2 sensor. $34 from RockAuto.com
The non-California cars got downstream O2 sensors starting in 1996. California cars had downstream O2 sensors prior to 1996 (off-hand, I don't know when this started).
I would strongly recommend you stick with the OE manufacturer: Denso.
Denso 2341053 is the upstream California O2 sensor. $28 from RockAuto.com
Denso 2342052 is the upstream 49 state O2 sensor $42 from RockAuto.com
I don't live in California, but I believe it is illegal to install non-California approved emissions equipment on a car registered in California. Just an FYI.
To answer your second question, I see no reason to attempt to clean the excess PB Blaster off anything before you drive. Can't see it harming anything or causing a fire hazard.
