Headlight Premature Burnout and Battery Warranties
Does this sound right to you folks. When Sylvania Silver Star Ultra's came out I bought them for both of my Toyota's. Within 1 year both of them burned out and they were expensive about $50 a pair and it's a bit of hassle because you have to pull the battery for one bulb per car.
I did wear plastic gloves when replacing them before, because I know that oils from you skin will wear them out faster.
So I go to my local Auto Zone store and they say well if you have used bulb grease then they would have lasted much longer.
Does that sound right? I really want the brightest lights but not if they are going to burn out in 1 year. I live in semi rural Colorado.
Second issue. My battery is going bad, have them test it, and they tell me we will give you a pro-rated credit but you only get the remaining warranty off the original battery. WTF? You want to give me a measly $35 credit on a $100 battery and then I only get the remainder of the original warranty, which will equal 1 1/2 years for $70. I have never heard of such info. When I had a tire warranty problem they give you pro rate and then a full warranty on new ones.
Looking for some helpful objective feedback. Thanks much.
