Convert 95 Corolla to OBD2 by replacing engine.
Hello,
I have a 1995 Corolla DX with the 7AFE engine and the 4 speed automatic transmission. I need to replace the engine and I was thinking of purchasing a 1996 7AFE engine with the additional parts needed to convert the car to OBD2. So far I have found the following differences:
Engine Control Computer
EGR Valve
EGR Temperature Sensor (None on 95)
Idle Air Control Valve
I assume also that the engine wiring harness may be different, as well as requiring the OBD2 connector to ECM harness, which may or may not be attached to other stuff in the cabin. Interestingly there appears to be a knockout under the steering column just the right size for an OBD2 connector.
I'm not sure but there appears to be an additional oxygen sensor somewhere, unless that is only for the California models.
I am wondering if I'm on the right track, or if I'm missing something. I am planning to get a complete engine and transmission with the wiring harness already attached and simply drop it in.
Daniel G.
