Originally Posted by slowrolla
First thing is first, disconnect the battery. I've swapped out my starter 3 times this last fall. Took out the air intake pipe. I was able to get to both bolts on the starter. With a little stretching you should be able to get the back bolt out. Only takes me about 30 minutes to swap out my starter.
Thats fast, but you have had practice and probabally a bit younger and more flexible, Im 59.
Glad I jacked it up, he said it had a slight water leak, with it jacked up saw water pump leaking
now doing timing belt, water pump and all drive belts
