Hey everyone.
Been messing around with my car some more. And decided to bleed my clutch again to possibly make it shift better in the cold + preventative maintenance.
Well I watched this
and thought that the whole pushing the slave cylinder in with your hand was a good idea.
So I went out got my bleeding apparatus all set up and got to work. Every time that I would push that slave cylinder in with the bleeder open I would get some bubbles. Then some huge air pockets when I would push the clutch pedal down just after doing that. It seemed like every time I would push that slave cylinder IN like in the video more air would just show up. I honestly repeated it almost 25 times. This air must have been coming out of "thin air" because there is no way my clutch would have been working with that much air in the system.
The only thing I did differently was that I would push the slave IN without the pedal on the floor. But the bleeder open. Then I would pump the pedal with the bleeder still open and tons of air would come out. I also did it exactly as described in the video and probably 4 other variants and AIR AIR AIR lots of air. Should been blowing up pool toys not bleeding hydraulics. I finally just kinda gave up. And bled it without pushing the slave IN until the bubbles stopped. The clutch pedal and shifting feel the same as ever to me. No better no worse.
Any one know what was going on here? Is my slave cylinder garbage? I never need to top up my clutch fluid and I know it holds pressure I just don't understand where all this air was coming from.
Ideas? Experiences? Suggestions?
P.S. air was not getting in from the bleeding nipple. I use that whole tube and a jar method like in the video it's pretty bullet proof.
