1996 Corolla engine replacement
I don't know if anyone else has run into this problem. I swapped out a blown 1.6 in my 96 SD with a good 1.6 from a 97 DX. I didn't change the wiring harness or the PCM, it all looked the same. I have everything hooked up, all the lights and accesories work fine and the car turns over but won't fire. The CEL doesn't come on when I turn the key to on position. I plugged in my OBD2 scanner to check for codes and it won't link to the PCM but the CEL now comes on and the car will start and run for as long as the scanner is hooked. Runs great but it smells like it might be running rich. What the hell did i do? Any suggestions? Both motors were manual trans and I did save the harness and PCM from the donor.
Thanks
