Hi, I have read two dozen posts and many videos and have never come across
- a situation with no crank with no click and finally starts after many times turning the ignition off and on...
- and other times it does click once every time i turn the ignition on and the car eventually starts.
...and the problem is getting worse over time.
I feel strongly towards buying a contact kit and plunger. But I have no experience here. Does anyone know when its a no click situation that contacts are ruled out?
I read if its no click, it might be the magnetic switch (which costs as much as an oem new starter), or it could be bad electrical connections.
I only read about one condition or the other, click or no click- but not both so i wonder which set of solutions are likely.
I have noticed its worse when its cold outside and my engine is cold (like many described with contact problems). It was
no crank no click for a very long time with few incidents beginning 5 weeks ago, but now its mostly
no crank with click and it now takes 6-30 trys before it starts. (it is possible it was clicked earlier and did not hear it, but it was mostly no click). Also, i was in an accident 6 moths ago... maybe so-meting came loose?
I thought it was my battery and replaced it, like so many other people i read about.
The first thing I will try is testing the ignition wire at the starter check the wires and the always hot post, but i feel its the starter.
I want to buy the contact kit on ebay, but it would suck to do all the work and still have a bad starter. I wonder if i should not gamble and but a new one. But money is very tight.
Thanx for any replies.
