95 corolla 4afe whining noise - uploaded sound file - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-19-2012, 08:20 PM   #1 (permalink)
View Ktroy's Photo Gallery
Most noticeable starting up when cold, seems to go away when warm. Sounds like a power steering groan but the car is just sitting idle warming up.
I had the hood open, started the car then stepped outside and placed camera near the water pump/timing belt area where it seems to be coming from.
Car has 59k miles.
whatever it is, It makes another noise at 1:00 in the audio clip.
Anyone have an idea what it could be?
audio clip
Ktroy is offline   Reply With Quote
Old 01-20-2012, 03:20 PM   #2 (permalink)
Found the answer. It has a power steering fluid leak, and was low on fluid. Apparently, the pump will make noise even at idle, without use of the steering, especially when cold.
Old 01-22-2012, 01:44 PM   #3 (permalink)
View tbalon's Photo Gallery
Yes, air introduced into any hydrolic pump will usually produce a whine... Glad you got it fixed.
tbalon is offline   Reply With Quote
Old 01-23-2012, 05:29 PM   #4 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
...unless its a Ford, then it whines anyway!
-SP
