Car Oil Light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2012, 12:03 AM   #1 (permalink)
Gameroom cash: $127900
View Bstylz's Photo Gallery
Car Oil Light
this tells that it needs an oiil change correct?
do you guys go by this light or do u change oil but checking the oil itself?
Bstylz is offline   Reply With Quote
Old 01-22-2012, 12:43 AM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
No, it tells you that you have no oil and are damaging your engine irreparably, as in you'll be buying a new car soon if you let it run this low on oil more than once or maybe twice if you're lucky.
Bitter is online now   Reply With Quote
Old 01-22-2012, 07:55 AM   #3 (permalink)
on full afterburner
Gameroom cash: $1344797
Check the dipstick regularly. Make sure the oil level is within the recommended range as stated in your owners manual.
You go by the manufacturers recommended oil change interval.
Old 01-22-2012, 12:25 PM   #4 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
If your oil level is correct and the light comes on at idle, the pressure sensor is bad and needs replacing.
-SP
Old 01-22-2012, 08:14 PM   #5 (permalink)
Token Aussie
Hiro Protagonist's Avatar
Gameroom cash: $179000
View Hiro Protagonist's Photo Gallery
-SP
Or the oil pump is stuffed. Much more likely to be the sensor, but it can be a costly mistake to just replace it without checking the pump.
Charlene - 1997 AE102 sedan: FXGT of awesome
Billie - 1981 KE55 sedan: GOOOONNNE
Rosie - 1986 AE82 Twincam Seca: Converted into garage space
Charlie - 1988 ST62 liftback: Moored in the garage
Lexi - 1995 JZZ30 GTTL: Hunting n00bs in Skylines and SS Commodores
Hiro Protagonist is offline   Reply With Quote
Old 01-22-2012, 09:20 PM   #6 (permalink)
View 96coroll's Photo Gallery
ya our oil light is not like newer cars where it'll come on after a certain amount of distance to tell you to change the oil.
My oil light came on one time, i was entering a highway took the ramp faster than i sud have and the light came on for a brief second. Well once i got home that day. I checked my oil and up it was barely on the dipstick.
So if you see the oil light as mentioned deal with it right away. And if you can check your oil regularly and never have it come on that would be ideal.
96coroll is offline   Reply With Quote
Old 01-22-2012, 10:10 PM   #7 (permalink)
Gameroom cash: $323345
View cipher93's Photo Gallery
Technically, the idiot light is different from what you're mentioning. A lot of cars now have service reminders but at least in our Mitsubishi it's a nightmare to set up and never has been used.
cipher93 is online now   Reply With Quote
Old 01-23-2012, 05:27 PM   #8 (permalink)
Andele, andele!
speedy25's Avatar
What the hell is that?
-SP
Old 01-23-2012, 06:15 PM   #9 (permalink)
Gameroom cash: $816401
View zythr's Photo Gallery
...You want a reason to sell this car?
-SP
It is probable the poster's way of saying the oil pump needs replacing
zythr is offline   Reply With Quote
Old 01-23-2012, 06:44 PM   #10 (permalink)
pdq
Gameroom cash: $220900
View pdq's Photo Gallery
Maybe he meant the oil pickup tube screen is clogged.
pdq is offline   Reply With Quote
Old 01-23-2012, 08:09 PM   #11 (permalink)
TIEyota fighter ace
Piloter's Avatar
Gameroom cash: $142700
View Piloter's Photo Gallery
Or that you're cornering hard enough to starve the pickup.
That said even when the oil has been two quarts low I haven't seen the light go on during normal driving, so yeah it's kind of a maintenance light...when it comes on, you're likely to need really expensive maintenance.
WIP AE102.
Piloter is offline   Reply With Quote
Old 01-23-2012, 08:50 PM   #12 (permalink)
You asked for it...
View azcorolla's Photo Gallery
I think it's Aussie for 'no good'.
as in:
hosed
screwed
f----d
kaput
...and so on.
azcorolla is offline   Reply With Quote
Old 01-24-2012, 01:45 AM   #13 (permalink)
Token Aussie
as in:
hosed
screwed
f----d
kaput
...and so on.
Exactly. Cactus is another one that gets used a lot.
Old 01-24-2012, 08:00 PM   #14 (permalink)
Andele, andele!
speedy25's Avatar
Ahhh I should have looked at his location to realize he wasnt writing in American English.
Now I have some new slang to confuse my "mates."
-SP
