Crunching sound in drive - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2012, 11:04 PM   #1 (permalink)
tylan71's Avatar
View tylan71's Photo Gallery
94 corolla with 126000 miles. Got in the car this am and there is a loud crunching sound while in drive. Smooth as can be in reverse. I was on the way to the airport so had to switch cars and couldn't look at it. Is that indicative of a transmission that has had it? Approximate cost to repair? BTW it's a1.6 L automatic. Thanks..
tylan71 is offline   Reply With Quote
Old 01-23-2012, 05:21 PM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Check your driveshafts first.
-SP
Old 01-25-2012, 08:16 AM   #3 (permalink)
tylan71's Avatar
Would a low differential fluid level cause this problem? If so, what are the chances that refilling the differential fluid might fix the problem? If I have reached this point, is there too much damage done?
Old 01-25-2012, 06:42 PM   #4 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
Yes, once it's broken it's broken assuming that's what it is. Drain the fluid, look for heavy metal.
Bitter is online now   Reply With Quote
Old 01-26-2012, 05:36 AM   #5 (permalink)
View jmarshall098's Photo Gallery
try flushing the trans fluid first to see if it helps. If the differential has been damaged then it is surely an expensive repair.
jmarshall098 is offline   Reply With Quote
