crank shifted about 10 degrees during timing belt change - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2012, 08:30 AM   #1 (permalink)
View Benchmark's Photo Gallery
I know your not suppose to rotate the crank counterclockwise but if its only off 10 degrees will it hurt? And if I do have to turn it clockwise is one full turn matching the crank pulley and 0 degrees on the cover top dead center? Any tips on keeping the crank from moving while installing the new belt. This is my first timing belt.
Thanks
Benchmark is offline   Reply With Quote
Old 01-27-2012, 08:07 PM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
Sometimes it can move as you work on it. Just rotate it back where it belongs. After installation and tensioning rotate a few times and make sure your marks line up like they should.
-SP
The Following User Says Thank You to speedy25 For This Useful Post:
Benchmark (01-27-2012)
Old 01-29-2012, 03:07 PM   #3 (permalink)
It's A Facial TN Member!
trife96's Avatar
View trife96's Photo Gallery
the key way should be directly upright. Just move it back to the correct position without rotating it. Just move it back slightly. If you rotate it, you will have to make sure #1 cylinder is TDC. You can use a couple long extensions and remove the #1 cylinder spark plug. Stick the extension in the hole. And as you turn the crank, watch for it to come up and down. Wait till it comes up as high as possible. This is will be TDC.
www.cardomain.com/ride/2950600
trife96 is offline   Reply With Quote
