problems with mounting 8th gen sideskirts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-28-2012, 05:36 PM   #1 (permalink)
96 Toyota Corolla
kickfli12's Avatar
Gameroom cash: $133700
View kickfli12's Photo Gallery
anyone have any experience with this? i dont do body work. the picture looks fine but if i bolt the skirt to the bottom of the car using the designated spots on the skirt, the skirt tilts away from the car and bows out in the middle. if i press the skirt against the car so it looks flush the bottom mounting part is angled toward the ground. im thinking of cutting all that off. any modifications to do the install?
i have a factory spoiler for sale.
http://www.toyotanation.com/forum/66...ake-light.html
kickfli12 is offline   Reply With Quote
Old 01-28-2012, 06:31 PM   #2 (permalink)
View trd808's Photo Gallery
i had 8th gen skirts on my car.
and i cut off the area you were talking about
trd808 is offline   Reply With Quote
Old 01-28-2012, 06:58 PM   #3 (permalink)
96 Toyota Corolla
kickfli12's Avatar
I figured that would need to happen. I even tried to bend it up using a heat gun. Also, did you take off the rubber moulding too?
Old 01-28-2012, 08:05 PM   #4 (permalink)
Yea I took the rubber off
Old 01-28-2012, 08:10 PM   #5 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291352
View gold94corolla's Photo Gallery
You actually need the mounting kit to mount it properly... there would be metal spacers and whatnot, to keep the skirt from mounting directly to the bottom of the car.
Usually, you don't need to put bolts under there like that... just on the ends should be fine. On the JDM skirts I used, I did use some screws up into the rubber bits, but only tightened enough to hold, not pull the skirts to touch the bottom of the car.
gold94corolla is online now   Reply With Quote
Old 01-28-2012, 08:52 PM   #6 (permalink)
96 Toyota Corolla
kickfli12's Avatar
Good cause I was tired of dealing with it.
Old 01-28-2012, 08:57 PM   #7 (permalink)
96 Toyota Corolla
kickfli12's Avatar
I'm just going to cut them and screw them on the ends like my old sideskirts on the prizm.
Old 01-28-2012, 09:16 PM   #8 (permalink)
the way i did mine was i cut away mentioned area, screws at the ends and i actually drilled 3 holes into the rocker panel and used the clips on the skirts to keep it flush with the body
Old 01-29-2012, 06:41 PM   #9 (permalink)
Super Procrastinator
modernage's Avatar
View modernage's Photo Gallery
The easiest solution is to just sell them to me.
modernage is offline   Reply With Quote
Old 01-29-2012, 07:00 PM   #10 (permalink)
96 Toyota Corolla
kickfli12's Avatar
I'll pass. Tomorrow is my day off so my bay will be open all day. They WILL be on tomorrow.
Old 01-29-2012, 10:45 PM   #11 (permalink)
or if you don't want to drill holes on the side like me then you can use double sided tape=D to hold them flush
Old 01-30-2012, 04:08 PM   #12 (permalink)
kennydang91's Avatar
View kennydang91's Photo Gallery
That looks good! Maybe I should've gone the 8th gen skirt route as well..
kennydang91 is offline   Reply With Quote
Old 01-30-2012, 07:50 PM   #13 (permalink)
Living on a Rock
kaitaiya's Avatar
Gameroom cash: $212950
View kaitaiya's Photo Gallery
the better method is to find some american billet 7th gen skirts.... bolt right on.
解体屋 Just a gearhead in paradise...
93 JDM AE102 20V Blacktop Blacktop Wiring DIY
The Somewhat tips and trick to the install
Proper Planning and Preparation Prevents P*** Poor Performance.
kaitaiya is offline   Reply With Quote
Old 01-30-2012, 08:21 PM   #14 (permalink)
96 Toyota Corolla
kickfli12's Avatar
I've never seen those before. Where did you get those?
Old 01-30-2012, 08:35 PM   #15 (permalink)
Living on a Rock
kaitaiya's Avatar
got them off here from a guy in canada. they actually sit on the lip under the doors. very quality product if you can find them. from what i've learned they are VERY hard to find. i sold them to a friend that's building a show car. to me they were nice, but my car isn't low enough to make the look.
