96 corolla - problem with NEW shocks - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2012, 11:45 AM   #1 (permalink)
View drew197's Photo Gallery
i just replaced the rear shocks/struts, springs and mounts. there is a loud metal on metal banging sound coming from both sides. the sound is coming from the back seat where the mounts attach. the middle bolt moves up and down (the bolt from the strut, not the bolts holding the mount in place)
does this bolt just need to be tightened? i was told that you are not supposed to have to tighten this bolt...when i look at the old strut, this area looks different. the old part has one large nut and there is very little thread left on the bolt. the new part has the same large nut, but a smaller bolt coming up out of it with another smaller nut on there...i am confused. please help
i'm going to take a picture to show what i am talking about
thanks
drew197 is offline   Reply With Quote
Old 01-29-2012, 01:17 PM   #2 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
tighten the center nut more, use the hex to hold the shaft. Did you get all the parts separate or did you buy a quick strut?
Bitter is online now   Reply With Quote
Old 01-29-2012, 01:45 PM   #3 (permalink)
i got the parts separate and i really regret that now. heres a pic of the 2 nuts
u cant see in the pic that the large nut has scratched the metal of the car underneath it from moving around. i wasnt sure which nut to tighten, or to do both, which one i should tighten first...
i sent an email to monroe too, just in case. since i have read that they have been known for some faulty parts
Old 01-29-2012, 02:16 PM   #4 (permalink)
Bitter's Avatar
I think you lost the spacer. There is a metal collar which acts as a spacer on the stock assembly, you cannot tighten the nut enough without the spacer. You could try to stack some washers or another nut under maybe, I don't know. I lost my spacer on one side and ended up finding another one from a parts bin at a hardware store that was close enough in size to work. Probably a fluke that I found it.
Old 01-29-2012, 06:48 PM   #5 (permalink)
Super Procrastinator
modernage's Avatar
View modernage's Photo Gallery
Yeah you need the spacer that goes under that huge bolt. Just looking at the picture I can tell the bolt is way too low with all that extra thread.
modernage is offline   Reply With Quote
Old 01-29-2012, 07:49 PM   #6 (permalink)
thank you so much guys... is it going to be ok to take the nut off and put the spacer in? please dont tell me i have to take everything apart again
Old 01-29-2012, 09:32 PM   #7 (permalink)
Bitter's Avatar
I think just nut off and spacer on, yes.
Old 01-29-2012, 09:51 PM   #8 (permalink)
corolla 95
moschinoespin's Avatar
View moschinoespin's Photo Gallery
this happen to me ...... hahahha
moschinoespin is offline   Reply With Quote
