Originally Posted by speedy25
BRAKES are SPONGY from either air in the lines or crappy brake fluid.
-SP
You could put water in there and not have a spongy pedal. Fluids don't compress. As long as the system is sealed and free of air, pedal should be hard.
Obviously yes, some brake fluids like silicone dot5 are more compressible than standard glycol brake fluid. And also obviously pouring oil into the brake system will cause a low pedal because all the seals fail. You could have brake fluid in there that's 20% water and 30 years old, still have a hard pedal (assuming you're not driving with it and boiling it). You'd have to have some real messed up shit in there, worse than just the factory fill at 15 years old.
