Popping when letting off throttle. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2012, 12:03 PM   #1 (permalink)
Nick
Gameroom cash: $155900
View TheNightWolf's Photo Gallery
Is that normal for a Corolla with a custom exhaust and running a bit rich, I have a CEL.
-1994 Toyota Corolla-Ksport Coilovers, custom exhaust, Weapon R intake with Ram Air Kit
TheNightWolf is online now   Reply With Quote
Old 01-30-2012, 05:43 PM   #2 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
I'll bet its NOT rich, but lean.
The noise is what you get for modifications.
-SP
Old 01-30-2012, 06:33 PM   #3 (permalink)
Nick
-SP
I always mix up the lean rich thing -.-
Either way its popping and burbling, is it bad or can it cause no problems?
Old 01-30-2012, 07:29 PM   #4 (permalink)
Living on a Rock
kaitaiya's Avatar
Gameroom cash: $212950
View kaitaiya's Photo Gallery
sounds like you have an exhaust leak. my truck had a little leak from the headers and when i would lift i would have a pop pop pop coming out the duals because air is getting into the exhaust from the leak and causing the unburnt fuel to ignite inside the pipes. check to see if you got some carbon leaking out where there are welds or connectors.
解体屋 Just a gearhead in paradise...
93 JDM AE102 20V Blacktop Blacktop Wiring DIY
The Somewhat tips and trick to the install
Proper Planning and Preparation Prevents P*** Poor Performance.
kaitaiya is offline   Reply With Quote
Old 01-30-2012, 08:34 PM   #5 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
Code?
Bitter is online now   Reply With Quote
Old 01-31-2012, 05:06 AM   #6 (permalink)
Nick
Originally Posted by Bitter View Post
Code?
I know what caused the light to come on
The air density or temp sensor got messed up, it was too short and me and some friends tried to lengthen wire on it and the light kicked on after that.
Old 01-31-2012, 06:19 AM   #7 (permalink)
Living on a Rock
kaitaiya's Avatar
The temp sensor not hooked up or left in the engine bay would put the Ecu into a false setting mode and could lower the power as well as fuel economy.
Old 01-31-2012, 09:11 AM   #8 (permalink)
Nick
I'm getting 35 mpg as it runs now, and as for power, I have no problems keeping up with my friends on the highway and from a dead stop at lights.
Old 01-31-2012, 03:53 PM   #9 (permalink)
View Corolla Sound's Photo Gallery
Have you figured out where your exhaust leak was that was causing the backfires/popping noise? Or even if that's what was causing it? Hopefully there were no weld issues.
Corolla Sound is offline   Reply With Quote
Old 01-31-2012, 04:12 PM   #10 (permalink)
TIEyota fighter ace
Piloter's Avatar
Gameroom cash: $142700
View Piloter's Photo Gallery
Could it be that the PCM's not cutting fuel on closed throttle? This is the classic fuel-burned-in-exhaust crackle.
, from about 13 seconds.
WIP AE102.
Piloter is offline   Reply With Quote
Old 01-31-2012, 07:48 PM   #11 (permalink)
Bitter's Avatar
That's all fine and dandy, but for the ECU to calculate the amount of air coming into the engine using Speed Density (as yours does...or should I say used to do), it does NEED to know the air temperature. It's two wires, how can you not extend that correctly? Two wires.
Speed density operation starts with the basic ideal gas law, which states the following relationship between gas (air) pressure, temperature and volume.
pV = nRT
Where:
p = absolute pressure of the gas (air in this case)
V = volume of the gas
n = amount of gas
R = gas constant
T = absolute temperature of the gas
So, you NEED the following sensors working:
Barometric pressure sensor (atmospheric air pressure)
Manifold Absolute Pressure sensor (engine vacuum)
Intake Air Temperature sensor (air temperature)
Crank or Camshaft position sensor (engine speed)
Now the magic happens, the ECM takes those inputs, with some math and the known displacement of the engine, the speed at which it's running, the difference between manifold pressure and atmospheric pressure, and the temperature of the air that's entering the engine, and voila knows pretty closely how much air is coming in. It needs to know the temperature to get one of the calculations, hell it's right in the name. Density! The density of air changes with its temperature. As of right now the ECM cannot tell the amount of air entering the engine, it's running off of assumed safe values which are often too rich or too lean for the actual operating conditions. It does get oxygen sensor feedback but may be ignoring it due to it missing that vital sensor input. Fix it. It's just two wires!
Old 02-01-2012, 05:19 AM   #12 (permalink)
Nick
I'm gonna fix it when I get a chance, and being colour blind and kinda twitchy its hard for me to do little things like wiring.
If it is a leak, I have access to a welder, and know people who can teach me or do it for me.
http://www.youtube.com/watch?v=TKGKETVpklk , from about 13 seconds.
It sounds more cracky than that.
I'm starting to guess its my exhaust setup, its 2 glass packs a 4-2-1 header, high flow cat and 2.5" piping.
If I can't find a leak, and I can get the CEL to go out and it still does it I'm gonna assume its the exhaust setup.
Old 02-01-2012, 07:36 AM   #13 (permalink)
Bitter's Avatar
heat seal crimps, so easy to use.
Old 02-01-2012, 11:23 AM   #14 (permalink)
Nick
Got it working for a bit then the light kicked back on -.-
I'm gonna have to find another way to wire it.
Old 02-07-2012, 05:46 PM   #15 (permalink)
Nick
Got a video, can kinda hear it.
I can get it to do it at 2k rpm in any gear except first and second.
I let of then tap it and it does it, but if I let off then hop on it does the same, that's how it happened the first time.
