Power steering hose leak - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-03-2012, 12:31 AM   #1 (permalink)
View ltai0001's Photo Gallery
Hello
I have a toyota corolla 93 7AFE engine. I traced the power steering leak to the high pressure hose. It is a small hole on the rubber part of the hose.
Is there a way to patch this without having to remove the hose (I heard its a pain to replace)
Thanks
ltai0001 is offline   Reply With Quote
Old 02-03-2012, 04:44 AM   #2 (permalink)
View Sgt_Lyna's Photo Gallery
Replacing it ain't that hard, you just don't have alot of room to work with... you can remove the left front wheel and unbolt it... on the other side remove the clamp and you're done Be advised, it can be a tad bit messy... since you can't really drain it easily
Sgt_Lyna is offline   Reply With Quote
The Following User Says Thank You to Sgt_Lyna For This Useful Post:
ltai0001 (02-03-2012)
Old 02-03-2012, 05:16 AM   #3 (permalink)
Andele, andele!
speedy25's Avatar
Gameroom cash: $235545
View speedy25's Photo Gallery
No you CANT repair it. Replacement is your only option.
-SP
The Following User Says Thank You to speedy25 For This Useful Post:
Old 02-03-2012, 07:49 AM   #4 (permalink)
By the other side you mean the pump side is that correct?
Old 02-03-2012, 07:50 AM   #5 (permalink)
-SP
do you think I can get a used one online that still works?
Old 02-03-2012, 07:51 AM   #6 (permalink)
Can I do this without removing the wheel?
Old 02-03-2012, 08:33 AM   #7 (permalink)
Yes indeed, as for removing the wheel... you can try it, but I recommend removing it... It's just four bolts and gives you the space you need...
Old 02-03-2012, 02:23 PM   #8 (permalink)
mobiless2's Avatar
View mobiless2's Photo Gallery
I did mine from the top, was not that hard. I purchased a hose on eBay, was about $35.00 & a direct replacement..
mobiless2 is offline   Reply With Quote
The Following User Says Thank You to mobiless2 For This Useful Post:
ltai0001 (02-05-2012)
Old 02-04-2012, 05:21 PM   #9 (permalink)
Andele, andele!
speedy25's Avatar
Used is NOT worth the headache of having to replace it again.
-SP
Old 02-05-2012, 10:52 AM   #10 (permalink)
I agree. There might be room to get to it from the top. I may have to remove the air filter housing. Is that what you did?
I will check eBay, that's a great idea pal...
Old 02-05-2012, 11:09 AM   #11 (permalink)
One more question
Do you know for the 93 model 1.8 L 7AFE if the hose has a flare fitting or an O-ring type fitting?
I don't want to buy the wrong hose
Thanks
Old 02-05-2012, 01:19 PM   #12 (permalink)
Bitter's Avatar
Gameroom cash: $558900
View Bitter's Photo Gallery
If they're asking you that, then I don't think they have the right hose since Toyota only uses one kind for the past few decades.
Bitter is online now   Reply With Quote
Old 02-05-2012, 01:59 PM   #13 (permalink)
You asked for it...
View azcorolla's Photo Gallery
If your car was built in America, it'll use the O ring type. If built in Japan, it uses a flare fitting.
You got a real good chance it was built in America, but look at your VIN - the first digit will be a J if it was built in Japan.
azcorolla is offline   Reply With Quote
Old 02-05-2012, 02:00 PM   #14 (permalink)
mobiless2's Avatar
This is the one I purchased. And yes I removed the air box.
http://www.ebay.com/itm/Omega-Hose-M...item2c61665e27
Old 02-05-2012, 09:52 PM   #15 (permalink)
Bitter's Avatar
I've never ran across a Toyota with a flare fitting, even some of the J vin Lexus I've worked on.
