I did check the EGR modulator and the air flow is fine. i cleaned the EGR valve cause it was really clogged. and then i did that Intake manifold cleaning using that same DIY you had a link too. and there was a lot of carbon blocking the hole to the EGR valve. so i got that out as best i could. and idk about the MAP sensor and the VPV...but if you said they dont go bad that easy...then im not too worried its that. but why would the CEL come on...?
The VSV do go bad. Actually, I would guess they are the most likely part to fail of the three (EGR, modulator, VSV). The problem is they fail intermittently. Will fail to open a few times triggering a CEL, but will work most of the time (and ALWAYS when tested
The MAP sensor should not go bad. The vacuum hose is a larger diameter hose connected to the bottom of the throttle body. If the hose is attached, you are probably OK.
If you cleaned the intake and plumbing to the EGR really well, I would check for vacuum leaks in the EGR system. Replace EGR vacuum hoses with the proper sized vacuum lines. Sometimes the aftermarket suppliers do not provide the correct size. They won't hold fit as well as the Toyota stuff. Just make sure you get some that fit well. Shouldn't cost much more then a few bucks.
If that fails, the next place I would go is the VSV valve. Would suggest a junkyard first then try a new unit if that fails. While you are at the junkyard, pull the modulator along with the VSV. Check it first to ensure if the plastic diagram is good. Buy it and replace it while you are in there. Total should be probably $10-20.
Last step would be replacing the EGR. Again, this can be easily tested by putting a vacuum on the hose that goes between it and the modulator (simply sucking on that hose if you don't have a vacuum pump). The car should stumble and/or die. If it does, IMHO don't waste your money on a new EGR.
