Key gets stuck in Ignition - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-20-2012, 07:06 AM   #1 (permalink)
View ajschwab2004's Photo Gallery
When I get in my car and try to put the key into the ignition it get stuck half way and doesn't seem to want to go in. I got to like wiggle it or play or even take the key out and put it back in several times b4 I can get it in the all way. I tried 2 keys they both do the same thing. This has been going for about a month now but seems to be getting worse now. Once I do get key the all way into the ignition the key is able to turn to ACC without any problems. Can someone tell me what's going on here, is my ignition switch done or is there DIY fix?
ajschwab2004 is offline   Reply With Quote
Old 07-20-2012, 07:17 AM   #2 (permalink)
Gameroom cash: $232050
View fj62's Photo Gallery
I blamed the PO (my sister)for the same problem with my 95 Corolla. She kept trying to use her other Corolla key. I replaced the ignition switch. Very easy on a 95 Corolla.
I would try some graphite lubricate which may help.
Dennis
2009 Highlander Hybrid, 2007 Camry, 1995 Corolla
Previous owned
1985 Camry, 1989 Land Cruiser, 1989 Corolla All-Trac wagon
fj62 is offline   Reply With Quote
Old 07-20-2012, 07:49 AM   #3 (permalink)
Living on a Rock
kaitaiya's Avatar
Gameroom cash: $298950
View kaitaiya's Photo Gallery
not the ignition switch, more the ignition lock. the lock activates the switch. the graphite lube may help, but you could take the lock out and have a locksmith repin it to your key. possibly it's worn out.
解体屋 Just a gearhead in paradise...
93 JDM AE102 20V Blacktop Blacktop Wiring DIY
The Somewhat tips and trick to the install
Proper Planning and Preparation Prevents P*** Poor Performance.
kaitaiya is offline   Reply With Quote
