Originally Posted by Mintho
A little question, I'm planning to put a 10mm spacers in the back wheels, will be any problem with the lug nuts?
or I will need to extend the *(forgot the work of it) the thingy that the lug nut lock on it?
maybe a smaller spacer like 70-80mm wide?
does somebody have tried here spacers on the AE's?
I used 15mm miata spacers. Miata's share the same hub bore and bolt pattern.
I needed longer studs. I matched mine up at the parts shop, the new ones ended up being dodge caravan wheel studs. Worked great.
04' Spyder 1E7 w/lsd
06' Corolla
94' Corolla, 20v, C160 LSD - Sold
93' Corolla, 4afte, C56 - Retired
Corners Quickly...
