some one said to start my own thread caz different year corolla add video - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-30-2012, 06:40 PM   #1 (permalink)
View cruzroy's Photo Gallery
Car sluggish at first, then picks up ::::: added video
ok , my name is mike, i just bought a 1994 toyota corolla, and it has 217,234 miles, and when i punch it it doggs out , but if i throttle slow it will drive ok, but i will have to pas some one someday, and today i was working on the rear brakes, and its about 23 degrees, and i started it and the belt squeels and it is slugish right away.....gets better as it warms up, but never goes away,
i9 notice the aircleaner was clogged bad, so i got a new one, i also got new plugs but did not install yet, and oil and filter, did not install yet,,
i got this car for my wife,its all i could afford right now, i dont think its safe right now, and it did not do that when i test drove it, and the guy i got it from says it never did that for him......but i dont believe him........every one sells a car for a reason, and i was in a bind.......i cant afford any thing right now and i get payed every 2 weeks, and im still only got 1 car.....It sucks, this year hasa been bad for me.....sorry about bitching, i bought this car and i think something i miss and its not safe for my wife, unless i can figure this out.......
so doggs when you punch it or try to pass people then picks up
i put new rear brakes
new aircleaner
i do have oil, filter and plugs,
tomorrow if it dont snow i will install that
is there a way to test map sensor, and the one near the aircleaner, i think its a temp sensor ???
thanks for any help
cruzroy is offline   Reply With Quote
Old 11-30-2012, 08:55 PM   #2 (permalink)
mobiless2's Avatar
Gameroom cash: $247000
View mobiless2's Photo Gallery
Squeeling belt can be a loose power steering or a/c belt, mine was loose recently. When I first purchased my corolla I had same thing sluggish taking off, found someone moved distributor back, just try and advance timing to see if it helps.
mobiless2 is offline   Reply With Quote
Old 12-01-2012, 10:09 AM   #3 (permalink)
well another bad day
out in the snow...i really needed to get this car ready for my wife, so i did the plugs, and i wanted to do cap and rotor..............and snap, one screw, in the distributer now i got 2 vehicals that dont run........i dont know what to do now, i dont have a tiny drill bit like that.......i was going to do a vid of when you gas it up it wants to die.........but it wont happen today
does the ditributor come out if i losen the 2 screws?????????? then i could bing it to be drilled out
thanks
Old 12-01-2012, 10:16 AM   #4 (permalink)
Senior TN Member
Gameroom cash: $393000
View leakyseals's Photo Gallery
Try changing the fuel filter and putting some fuel system cleaner it it. Use a fuel system cleaner that contains the additive PEA. Those are techron concentrate plus, gumout regane, gumout high mileage, gumout all in one. Use 2 or 3 bottles in 2 or 3 consecutive tank-fulls.
Need to get fuel delivery out of the way, then go after other possibilities.
02 Camry XLE 2AZ-FE 268k M1 HM 5w30 10k OCI
08 Pontiac GP 3800 Series III 80k PU 5w30 OLM OCI
Both: Fram Ultra, PEA, MMO, RMI-25
leakyseals is offline   Reply With Quote
Old 12-01-2012, 10:32 AM   #5 (permalink)
mobiless2's Avatar
What about putting g a large zip tie around distributor? Temporary.
Yes if you remove both screws distributor can be removed.
Old 12-01-2012, 11:13 AM   #6 (permalink)
so it will just pop out
i just need to remove 1 broken screw, so remove 2 bolts, REMEMBER where th rotor is pointing,,,,, i assume, and pull.....then i can drill out screw
would the throttle positioning sensor cause whats happening......it starts, it runs, it drives......Till you punch it.........it stumbles all over......but it wont die ???? i got no code.......the cap and rotor do look old ........so im going to get thse 2 items,,,,,,,,and ill be back
Old 12-01-2012, 03:58 PM   #7 (permalink)
Ok today is done.......and i found this
i got the distributer back together...SO
i got
new plugs
new cap
new rotor
new air cleaner
new rear brakes
and now i did the e1 te1 jump and got code 24 no other codes
still sluggish
please watch video at begining if thread
Old 12-03-2012, 06:11 AM   #8 (permalink)
Anyone????????????????
Old 12-03-2012, 06:41 AM   #9 (permalink)
mobiless2's Avatar
Code 24 is the intake air temp circuit. When you replace air filter you might have disconneted sensor.
Old 12-03-2012, 06:46 AM   #10 (permalink)
Senior TN Member
Just listened to your video. I do not agree with the auto parts store. In one case your slowly increasing fuel, its fine. In another your calling for fuel fast, its wants to stall. That is the symptom of a clogged fuel filter (among other things). Also, spraying carb cleaner down the intake wont do anything to clean injectors or fuel system, very little to clean the throttle body unless you physically use something to wipe deposits off. As a first step I would use a PEA fuel system cleaner in the gas as stated in a prior post. And physically clean the throttle body and IAC valve located on the TB. Then perhaps the fuel filter or pump.
But before the fuel filter or pump..I'm not clear on this, what is the CEL code lit on your dash again?
Old 12-03-2012, 07:07 AM   #11 (permalink)
Senior TN Member
If cleaning the TB and IACV manually, adding fuel system cleaner doesn't resolve things...
Locate the MAP sensor located in the top of the the intake box behind the air filter. While cleaning the tip may help, usually a replacement is best. There is also a fuel pressure regulator located near the rail. Wouldn't hurt to replace that also.
Old 12-06-2012, 07:29 PM   #12 (permalink)
Well guys all i can say is....yeah
i did a water test with the plug wires....................and they did not fail, (i didnt want to buy new ones, they where 50 bucks??)
so i put them in.............still no change
so i have a 1994 Prizm............i took the wires out and thied them......ran like a dream
so i payed 50 bucks............oh she still skipped alittle, so i also twisted te distributor.......that helped to
got new tire today too...........hope the wife can deal with this till i fix her truck
1400.00 for car, good shape but 217000 miles..1400.00
new rear brakes, springs, and drums...............75.00
new rear struts............................................ ..128.00
4 new headlight bulbs......................................10.00
2 1156 amber rear blinker lights.......................7.00
4 new tires............................................. .........317.00
total so far............................................... .....1937.00
still need regirstration
and e-brake cables
