Hi, my name is Bob. I have a 1995 Toyota Corolla DX that I have owned since 1998 it has 252,000 miles on it and still runs as good as the day I bought it.
My horn quit working so I took off the steering wheel cover and found that the wire for the horn was moving in the connector so I soldered it. Well now my airbag light is on. Does anyone know how to reset the SRS light. Researching this they say to find the yellow connector in the fuse box and short the terminals with a paperclip. Problem is I do not see a yellow connector at the fuse box on the drivers side fuse panel under the dash. Can anyone help me. Also, just a note the horn still isn't working- fuse ,horn and relay are good.
tried again light still stays on. need to short the connector, just need to know where to locate it at. it could be possible that the clock spring is faulty since my horn no longer works. if anyone has an answer i would appreciate it. i am a former toyota tech however i was never taught how to reset the srs system
If you have no emotional attachment to the car, sell it (letting the buyer know the issue) and get something else. Barring that you could get one of those clown horns and rig it up to the outside rear view mirror with the control for it inside and use that as your horn, It may be silly, but it might just work.
i have no intention of selling it at this time. I don't give up when there is a problem. I will get this cleared. The car may be old but it runs great, Never had a major problem.. Serious replies only, Please
That was a serious reply. You asked for help, and that is what I was trying to do. Sorry if you felt it came off as harsh, If you have not already you might want to see if you can locate a Toyota authored (not Chilton's or Haynes) service manual. There will be information/suggestions on how to get the SRS light off and maybe fix the horn as well. Knowing Toyota, the manual will be split up into 2 parts, Body and Mechanical.
There just happens to be service manual(s) on E-bay, now, though they may be pricy depending on what you want to spend.
Hello. I had a similar problem with my '97 Corolla. The airbag light just appeared suddenly for no reason. If it's only the fact that the light is on that bothers you(and not the underlying issue that could be causing it), I can offer you a simple solution that worked for me. Unscrew the dashboard and just pull out the airbag indicator light out.
Mind you, this will, obviously, not fix any problem there might be(or might not be) with the actual airbag.
My father has a problem like you but not the airbag. I don't remind well but my father was solving a problem in the steering wheel(not in relation with the airbag). But he had a emergency call soo he drove the car without the cover of the steering wheel and without reconnecting the plug of the airbag if I remember well. After he started the engine the light come on but he had no time to complain. After the emergency call resolved, he reconnect the airbag plug and finish to repair the main problem. But even after he replugs the terminal the light stay on. Soo after reflexion(my father is a mechanic), he changed the airbag module situate under the armrest(a yellow box) and light shut off. He comes to the conclusion that you have to reconnect the airbag plug before you reconnect the battery(because of course you have to disconnected the battery before playing with electronic composant xD).
I think you try the horn without reconnecting the airb plug. And for you horn check if the conectors in the horn are not rusted in the front of you car.
