1995 Geo Prizm engine shake on acceleration - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 7th Generation (1993-1997) Specific discussion of the 7th generation
post #1 of 8 Old 12-05-2008, 04:42 PM Thread Starter
paxman356's Avatar
Quoted: 0 Post(s)
(Thread Starter)
My car has developed a problem, and I don't know whether to solve it or how. It is a 5 speed with the 1.8. During acceleration you can feel a little shake on throttle tip in, like the engine is lose from the car, or the transmission. Can't explain it any better.
What is the best way to figure out what is wrong, and how could it be fixed?
paxman356 is offline
post #2 of 8 Old 12-05-2008, 05:41 PM
Senior TN Member
cipher93's Avatar
Quoted: 706 Post(s)
Pop the hood, and watch while someone revs the engine. If the engine is shaking excessively, it's likely worn out motor mounts. Where is the shake? Your wording makes it sound like its in the pedal, but I think you mean the front end/whole car vibrating
cipher93 is offline
post #3 of 8 Old 12-05-2008, 07:47 PM
Quoted: 0 Post(s)
yep CJRocker is right!
Mine does that but only a little shake so I took it in and they said it was motor mounts and it was gonna cost about 300 to fix them. Ill just buy them and put them in myself.
When you rev the engine make sure you stomp on the gas and dont accelerate slowly
DylansROLLA is offline
post #4 of 8 Old 12-05-2008, 07:50 PM
Bitter's Avatar
Quoted: 1613 Post(s)
roughness on acceleration is also a common symptom for a misfire.
Bitter is offline
post #5 of 8 Old 12-09-2008, 09:14 AM Thread Starter
paxman356's Avatar
Quoted: 0 Post(s)
(Thread Starter)
It's probably the motor mounts. My wife has the car right now, but I'll look into it tonight. I can rev it from the engine bay, and have, but haven't seen or felt anything when it is out of gear. Thanks for your help so far.
post #6 of 8 Old 12-09-2008, 07:02 PM Thread Starter
paxman356's Avatar
Quoted: 0 Post(s)
(Thread Starter)
Took a look at it again tonight. There is no shake from just revving the engine. It's pretty steady. If you are out, in gear, and rolling down the street and hit the gas to pas, it's like the engine jumps. This only happens in gear, however.
post #7 of 8 Old 12-09-2008, 07:15 PM
kor-ro-ra?
midnightmach's Avatar
Quoted: 0 Post(s)
take the distributor cap off and check for corrosion, mine was hesitating under acceleration and all the contacts were corroded. i got a new one and problem solved
2001 Solara V6 (5MT) TRD Supercharged
1997 Corolla (5MT)
1992 Camry (5MT)
midnightmach is offline
post #8 of 8 Old 12-09-2008, 09:51 PM
Quoted: 0 Post(s)
agreed. All of those are possibilites. I am guessing the motor mounts, and the distributor cap. I hope u get it solved soon man.
toyotaman15 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 7th Generation (1993-1997)
User Tag List
Linear Mode Linear Mode
Back
