Blown AM2 30A Fuse - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 7th Generation (1993-1997) Specific discussion of the 7th generation
post #1 of 13 Old 08-29-2009, 03:41 PM Thread Starter
hachuelo's Avatar
Quoted: 3 Post(s)
(Thread Starter)
USA Blown AM2 30A Fuse
Hello everybody I have a 97 Corolla with the AM2 fuse blown I crank the engine but doesn't start,today I replaced the fuse with a 12V bulb and it lights so that is a clear indication that I have a short somewhere.Does anybody have faced that problem before? Thanks
hachuelo is offline
post #2 of 13 Old 08-29-2009, 04:18 PM
Quoted: 1 Post(s)
symptoms?
thoughts:
check the distributor for a problem with the coil,etc.
Maybe a leak in the ignition system that is shorting to ground because of insulation break. Disconnect the wires to the diustributor (not the plug wires) and retest test light.
Maybe a bad ignition switch.
97' Corolla, CE, 4AFE, 1.6, AT, 4d
2006 Tacoma, 2TR-FE, 5 speed, single cab
kevmac is offline
post #3 of 13 Old 08-29-2009, 04:52 PM Thread Starter
hachuelo's Avatar
Quoted: 3 Post(s)
(Thread Starter)
Ok I checked the ignition and pickup coil according to Haynes manual and they are fine the only thing was the condenser that was shorted but I replaced the distributor without the condenser and still the same.
hachuelo is offline
post #4 of 13 Old 08-30-2009, 11:48 AM
Quoted: 1 Post(s)
I'm lost.
You put the old distributor back without a condenser?
Unplug the connectors to the distributer and see if the leak still occurs at the fuse. Remove the ignition switch and test again for the leak. I assume what you meant in OP is that you found a leak while the key was removed.
kevmac is offline
post #5 of 13 Old 08-30-2009, 02:24 PM
Quoted: 0 Post(s)
Hello, i had this happening to one of my customers cars once. If i remember correctly the AM2 fuse also powers the injectors, turned out he had done his valve cover gasket a month prior and pinched the wire under his valve cover. Just some food for thought. But I def remember the AM2 being the supply for the distributor and injectors.
Spelick is offline
post #6 of 13 Old 08-30-2009, 06:38 PM Thread Starter
hachuelo's Avatar
Quoted: 3 Post(s)
(Thread Starter)
Originally Posted by kevmac View Post
I'm lost.
Well correct me if I'm wrong but the function of the little condenser inside the distributor is avoiding sparks cause any interference on the radio right? Is there any chance that it would be caused by the igniter or the ECM? Thanks
hachuelo is offline
post #7 of 13 Old 08-30-2009, 07:25 PM
Bitter's Avatar
Quoted: 1474 Post(s)
Basically the function of a condenser in a coil ignition circuit is to reduce the spark at the contact points as they open in the distributor and thus minimise burning and pitting of the points. Arcing is caused by the effect of self induction in the coil as the points interrupt the flow of current. The resultant collapse of the magnetic field produces a high voltage to be generated in the primary winding which then tends to flow across the points, thus causing burning or pitting. This current flows into the condenser and charges it as the points open the rapid collapse of the magnetic field produces this high voltage in the primary windings, which can be as high as 250 volts. This further charges the condenser and the consequent collapse of the field causes a high voltage to be induced in every turn of both primary and secondary windings. As the secondary winding has about 100 times the number of turns of the primary, the voltage can reach as high as 25000 volts. Normally this voltage is not reached as it is limited by various factors such as point gap, compression, engine revs. Etc. so only sufficient voltage is produced to produce a spark at the plug. As the spark is produced at the plug gap the energy in the coil, stored in the form of magnetic flux, begins to drain from the coil through the secondary circuit thus sustaining the spark for a fraction of a second or several degrees of crankshaft revolution. During this interval the condenser discharges back through the primary winding producing an oscillation of the current flow in the primary circuit for the brief interval that is required for the primary circuit to return to a state of equilibrium. The condenser DOES NOT DISCHARGE UNTIL AFTER the spark has occurred at the spark plug.
http://www.austin7club.org/Ignition%20Condensors.htm
while we have no points, the condenser now just serves to quiet ignition noise these days.
Bitter is offline
post #8 of 13 Old 08-31-2009, 06:37 PM Thread Starter
hachuelo's Avatar
Quoted: 3 Post(s)
(Thread Starter)
Today I installed an ignition module and still the same:engine cranks but no spark.
hachuelo is offline
post #9 of 13 Old 08-31-2009, 08:14 PM
Quoted: 1 Post(s)
Your confusing me
o.k., you have a blown fuse. You removed the condenser. You replaced the ignition module. Did you replace the blown fuse? Is it blown again?
I think your distributor is probably bad.
kevmac is offline
post #10 of 13 Old 08-31-2009, 08:31 PM Thread Starter
hachuelo's Avatar
Quoted: 3 Post(s)
(Thread Starter)
No I haven't replaced the fuse yet because I'm afraid of blowing it again (they are almost $5 a pop) I'm still using the light bulb instead,tomorrow I'm going to get a new distributor a new fuse and give it a shot.
hachuelo is offline
post #11 of 13 Old 08-31-2009, 10:48 PM
Quoted: 1 Post(s)
Might be worth one more $5 pop to see if that condensor trick worked before paying for a new distributor. Also before shelling out $125, double check the wiring to see if any wire is pinched or burnt. Just a thought. BTW, don't screw up the distributor rotor direction when install the new one (and the one you put back for that matter). You have to point to the current cylinder plug in the firing order as I'm sure you already know.
kevmac is offline
post #12 of 13 Old 09-01-2009, 12:26 PM Thread Starter
hachuelo's Avatar
Quoted: 3 Post(s)
(Thread Starter)
Finally this morning I found the problem,The first thing I did was to replace the bulb for a new fuse and the car started right up so next I connected my old ignition module back and the car started right up again so obviously my module is fine (returning the module back to the junkyard is not accepted so they gave me credit on another parts that I needed);while I was doing the final checkup after finished working I found another fuse close to the one that was blown with signs of a green rust inside so I came to the conclusion that it was the cause for the fuse to gave up.Well the important part is the car is working fine now.Thanks for all your replies specially to kevmac.
hachuelo is offline
post #13 of 13 Old 02-26-2015, 08:58 PM
Quoted: 0 Post(s)
I found the cause
Im working on a 93 corolla with no spark that has blown the 30 amp fuse. the check engine wouldnt light either. i ran it through a cheap 30 amp fuse ad it blew when i turned the ignition switch on.
i hooked a light bulb across the terminals with the ign on and it lit brightly, indicating a ground. the elec diagram in the haynes manul shows it only goes to the ign fuse under the dash and to the distributor. when i unplugged the smaller harness leading to the distributor, it glowed dimly. this harness goes to the ignitor. inside the distributor, i see that this wire splits off to the ign module, the ignitor and the condenser. i tested each of the wires to see which was grounded and it was the condenser. i saw that it was visibly melted. ill replace it tomorrow and i bet we're good to go. cheap easy fix. i did need to remove the ignition module to get the condenser out.
raymilosh is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 7th Generation (1993-1997)
User Tag List
Linear Mode Linear Mode
Back
