crank sensor location ? - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 7th Generation (1993-1997) Specific discussion of the 7th generation
post #1 of 12 Old 12-30-2009, 04:27 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
96 corolla DX 1.8
need to find out where the crank position sensor is located.
would help if there's a pic
thanks everyone !
corolla7860 is offline
post #2 of 12 Old 12-31-2009, 02:35 AM
Full Throttle
Kiwi-Corolla's Avatar
Quoted: 15 Post(s)
iTrader Score: 16 reviews
It should be located by the timing belt cover, near the crankshaft pulley.
Here's a photo scanned from my Haynes manual:
Kiwi-Corolla is offline
post #3 of 12 Old 12-31-2009, 11:50 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Thanks very much ! does the manual indicate where the camshaft position sensor would be as well ? I understand they are two different sensors. one for camshaft the other for crank shaft. thanks again for all your help. !
post #4 of 12 Old 12-31-2009, 12:56 PM
Full Throttle
Quoted: 15 Post(s)
No worries. I can't find anything in the manual about the camshaft position sensor, but I believe that it's inside the distributor.
P.S. Happy new year!
post #5 of 12 Old 12-31-2009, 01:01 PM
Official TN Toaster
iToaster's Avatar
Quoted: 0 Post(s)
That's correct, the camshaft position sensor is part of the distributor.
1998 Lexus GS 300 - 2JZ-GE - 202
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
1995 Corolla LE - 8K1
iToaster is offline
post #6 of 12 Old 12-31-2009, 01:18 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
from what I have gathered so far from research is that after 96 onwards with the introduction of OBD2, the manufacturers eliminated the distributors and therefore had two separate sensors. one for crankshaft and the other for camshaft. then again i could be wrong...
the car is giving a p0340 code upon checking the check engine light and is not starting up.
it stopped while driving. now it cranks but doesn't start...
post #7 of 12 Old 12-31-2009, 01:29 PM
Official TN Toaster
iToaster's Avatar
Quoted: 0 Post(s)
Originally Posted by corolla7860 View Post
from what I have gathered so far from research is that after 96 onwards with the introduction of OBD2, the manufacturers eliminated the distributors and therefore had two separate sensors. one for crankshaft and the other for camshaft. In the 96 there is no distributor.
I'm not sure where you get your information from, but distributors were still used in the '96 and '97 model years for the Corolla. The only changes for OBD2 were the addition of some hardware required by it, like the crankshaft position sensor.
iToaster is offline
post #8 of 12 Old 12-31-2009, 01:35 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
interesting. OK so the code p0340 which is for the camshaft position sensor would require changing the distributor ? given the cam position sensor is part of it ?
thanks again for everyone's help and support on this !
post #9 of 12 Old 12-31-2009, 01:44 PM
Full Throttle
Quoted: 15 Post(s)
Yep, as far as I know you need to replace the whole distributor in order to replace the sensor.
post #10 of 12 Old 12-31-2009, 01:48 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
anyway to check if the sensor inside the distributor is OK before i replace it whole unit ?
does the haynes manual give any information on that ? thanks.
any info on replacing the distributor in haynes would be helpful. I"m a semi DIY
post #11 of 12 Old 12-31-2009, 02:22 PM
Full Throttle
Quoted: 15 Post(s)
I'm not very clued up on the electrical system of cars (does my head in) but you may be able to do a continuity check with have a continuity tester. You can also check the earth at the same time. It could even end up being a problem with the wires.
The Haynes doesn't mention anything about performing a test on the camshaft sensor or distributor, but it does have resistance specifications for the distributor if you need them. It might pay to ring an auto electrician and ask if he knows of a way to test the actual sensor itself.
post #12 of 12 Old 01-24-2013, 05:36 PM
Quoted: 0 Post(s)
I had the same problem
You have to replace the main AM2 fuse under the hood in the fuse box.
Replace the Distributor cap and rotor.
Replace the crankshaft position sensor.
then your good to go
I also just replaced the plugs and wires too. and fuel filter since the airbox was removed and it was cheap. Basically your doing a MAjor tuneup.
for future reference the AM2 fuse controlls the fuel pump and ignition. it will pop if you do not replace the distributor as the condensor inside causes this because its fried.
jbollinger0 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 7th Generation (1993-1997)
User Tag List
Linear Mode Linear Mode
Back
