any ideas? Car idles, but then dies when put into drive - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 7th Generation (1993-1997) Specific discussion of the 7th generation
post #1 of 15 Old 03-10-2010, 07:08 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Hey all...
I have 1995 1.8 corolla.
Go to start, starts right up. Idles fine. Put into drive and it starts to hesitate and then ultimately just dies. ONLY if I put it in Drive. Keep it in park, and you can rev it just fine. After it dies, it takes a few more cranks to get it started, but always starts and idles...until you go in drive.
Any ideas?
I ruled out the plugs, cap, rotor - they all looked ok
I ruled out the fuel pump and filter - as the car revs just fine
I'm new to toyota..like only 1 week new so bare with me
Thanks!
jibbajabba is offline
post #2 of 15 Old 03-10-2010, 07:50 PM
Official TN Toaster
iToaster's Avatar
Quoted: 0 Post(s)
Will it keep running if you give it throttle? I feel like the idle air control valve could be gummed up a little bit. If it still dies with throttle, I think that it might be that the torque converter is stuck locked up... which is typically a difficult problem to fix.
1998 Lexus GS 300 - 2JZ-GE - 202
2000 Celica GT-S - Supercharged 2ZZ-GE - 6 Speed - 3P0
1995 Corolla LE - 8K1
iToaster is offline
post #3 of 15 Old 03-10-2010, 08:17 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
When in park, you can give it throttle..no stalling
When you put in Drive, Reverse or L, it will idle for a few seconds then begin stalling then stall out.
If you apply the gas it just stalls out.
The engine does rock a little when drive is engaged, but nothing abnormal.
post #4 of 15 Old 03-10-2010, 08:18 PM
Sine Deviance's Avatar
Quoted: 0 Post(s)
As iToaster said, it's possibly a locked torque converter. It actually happens pretty frequently. Don't let him scare you, it's not THAT difficult to fix. You have to drain the transmission, pull it, replace the torque converter, bolt the transmission back onto the engine, and fill the system with fluid. There's a little more to it than that, of course, but it's relatively straightforward. It's just time-consuming. It's a lot like replacing a clutch on a manual transmission.
'94 Corolla DX Wagon - 1.8L 7A-FE - 4-spd A/T - Phillips CrystalVision 5000k Headlamps - 15" MB Vipers wrapped in Falken Sincera SN-828 185/65 R15's
http://sinedeviance.co.cc/
Sine Deviance is offline
post #5 of 15 Old 03-10-2010, 08:26 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Any other tests that might help confirm this...??
post #6 of 15 Old 03-10-2010, 08:31 PM
Bitter's Avatar
Quoted: 1474 Post(s)
could even be a bad fuel pump or weak ignition coil.
Bitter is online now
post #7 of 15 Old 03-10-2010, 08:40 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Because I'm able to rev the crap out of it in park and neutral...I ruled both of those out.
post #8 of 15 Old 03-10-2010, 09:15 PM
Official TN Toaster
iToaster's Avatar
Quoted: 0 Post(s)
If you can put it in neutral and get it to roll then shift to drive, it should drive normally as long as you don't stop. That is, however, dangerous... but if it lurches forward before stalling it's pretty much a bad torque converter.
iToaster is offline
post #9 of 15 Old 03-10-2010, 10:38 PM
Bitter's Avatar
good reasons, in that case it does sound like it could be a trans problem.
post #10 of 15 Old 03-15-2010, 02:45 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Just a follow up for future seekers...
It was the ECU that was faulty. $90 at the junk yard and all is good.
Thanks.
Edit:
WRONG - it was all good because it was cold. Same problem once it was up temp. DOH. Back to diagnosis.
post #11 of 15 Old 03-17-2010, 10:34 AM
Quoted: 0 Post(s)
Im curious to what the end result is, mines doing almost the exact some thing, starts and idles GREAT, I can get mine to drive but almost immeditaly it feels like either the torque is locking up and releasing or just slipping, and when it does the car just about stalls out, sometimes if Im going slow it will stall....Im thinking torqueconverter/tranny also.
g2nick is offline
post #12 of 15 Old 03-17-2010, 10:40 AM
PatrickGSR94's Avatar
Quoted: 42 Post(s)
I sure hope I never have to drop the trans off of our 96. Damn heavy@$$ slushboxes. I'll be using my cherry picker to lower it down to the floor if I have to.
PatrickGSR94 is offline
post #13 of 15 Old 03-17-2010, 10:57 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Well I tracked it down.
It was a bad ignition coil.
Replaced it with a new one...and NOW its fixed. Finally.
post #14 of 15 Old 11-09-2015, 04:28 AM
Quoted: 1 Post(s)
i have a similar problem on my 2004 rav4, the car is miles away from me, but wife reports that check engine light is on.
wondering if replacing the ignition coil will disable/trigger the secutiry etc
earthrealm is offline
post #15 of 15 Old 11-09-2015, 07:03 AM
Bitter's Avatar
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 7th Generation (1993-1997)
User Tag List
Linear Mode Linear Mode
Back
