Aftermarket Tach install (under $20) with PICS!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 7th Generation (1993-1997) Specific discussion of the 7th generation
post #1 of 20 Old 06-27-2012, 02:49 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
I have a base Corolla and it doesn't have an OEM tach. I like to know my RPM's so I was on the lookout for a cheap tach. I got this today in the mail:
http://www.ebay.com/itm/330754087487...84.m1439.l2649
Install took about 30 mins.
That is a conduit connector 2" bought at Menards for $1.42
It is zip tied to the cassette holder box. Hole drilled for wiring
dwcopple is offline
post #2 of 20 Old 06-27-2012, 02:52 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
wires go from the diag port in the engine bay. the ground was tapped down by passenger kick panel. the wires come into the cabin through where the A/C evap lines were.
Done
dwcopple is offline
post #3 of 20 Old 06-27-2012, 05:08 PM
4afte FTW
pnyk33's Avatar
Quoted: 0 Post(s)
Creative, but could of been done a little cleaner
300whp 4afte 450 hp S14 Boosted IS300 soon. 1,000hp 72 Chevy Nova to Bad Ass for my Sig
pnyk33 is offline
post #4 of 20 Old 06-27-2012, 05:19 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
thanks, but it is a $1300 car. What isn't clean?
dwcopple is offline
post #5 of 20 Old 06-27-2012, 07:18 PM
Quoted: 0 Post(s)
Yeah wish I had one of those... Did you have to calibrate it somehow?
gomes512 is offline
post #6 of 20 Old 06-27-2012, 08:50 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
it has a 4/6/8 switch on the back for how many cylinders it needs to read for. Otherwise it is all set. It gets its signal from the IGN port from the DIAG under the hood.
dwcopple is offline
post #7 of 20 Old 06-28-2012, 06:34 AM
Vivir el momento
Quoted: 34 Post(s)
He's probably referring to the mounting position of the tach.
As long as it works for you and you like it that's all that matters.
PhatRoyale is offline
post #8 of 20 Old 06-28-2012, 03:32 PM
Only GOD Knows
trife96's Avatar
Quoted: 86 Post(s)
Well, not to burst your bubble, but you could have done a gage cluster swap from another Corolla with the tach already in it from the factory. It's plug n play
trife96 is offline
post #9 of 20 Old 06-28-2012, 03:56 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
but then the gas gauge would be off and have you seen what those clusters are selling for???
dwcopple is offline
post #10 of 20 Old 06-28-2012, 07:55 PM
Bitter's Avatar
Quoted: 1613 Post(s)
I'll agree in this case, if you have a manual and just want to be cheap and drive it then what he did was fine. Having a tach helps when you're new to driving stick and if its just your cheap daily driver beater then who really cares, right? I scored my cluster for like $50 CHEAP on ebay, deal of a lifetime sort of thing.
Bitter is online now
post #11 of 20 Old 06-28-2012, 08:49 PM
4afte FTW
pnyk33's Avatar
Quoted: 0 Post(s)
Done
this^
you should of made you a plate cut a hole then install the gauge.
pnyk33 is offline
post #12 of 20 Old 06-28-2012, 11:08 PM
Bitter's Avatar
But he's only got the one gauge, this way he still can use the other half of the cubby. Personally I'd have gotten a single gauge cup and pillar mounted it.
post #13 of 20 Old 06-29-2012, 07:55 AM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Bingo
dwcopple is offline
post #14 of 20 Old 06-29-2012, 09:17 PM
h0yitsdom's Avatar
Quoted: 0 Post(s)
nice DIY if i didn't have an OEM tach i most likely would just put it on top of the dash on the left. my shift knob would get in the way of that mounting area and i like my cubby hole
h0yitsdom is offline
post #15 of 20 Old 06-30-2012, 08:01 AM
Only GOD Knows
trife96's Avatar
Quoted: 86 Post(s)
Actually the gas gage is only off in the middle, full is full and empty is empty...to me is the most important, I've actually gotten a good understanding of the sweep since I did mine. And I've picked them up from the junkyards for $20 all day long. But I must admit, I would have never figured out how to hook it up. I've heard mixed answers on how to hook it up. Some people said it would read off the alternator somehow. How did you know which wires to use in the diagnostic plug?
trife96 is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 7th Generation (1993-1997)
User Tag List
Linear Mode Linear Mode
Back
