Re: Having trouble starting car...Corolla
<henree21@gmail.com> wrote in message
news:1151029962.485408.140100@g10g2000cwb.googlegroups.com...[color=blue]
>I have a 96 corolla. And I recently had trouble starting it in the
> morning. I have had this issue before. And usually changing the battery
> was the correct remedy. So I changed the battery 5 days ago. And the
> car had no trouble starting up until today. Right after work, at around
> 6:00 pm. I had a heck of a time getting the car to start. Could this be
> the battery again? Or could there be underlying problems?
>[/color]
The only way to tell whether the problem is the battery or not is to test
the battery.
What symptoms are you experiencing? If you are hearing clicking sounds and
the battery checks out as OK, then check the condition of the contacts in
the starter relay. The contacts are available separately and are
replaceable.
Ray O
