Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Need alittle help...
View Single Post
Old 06-22-2006, 11:18 PM   #5 (permalink)
stepho
RA28 + MX73
Gameroom cash: $107620
View stepho's Photo Gallery
Oops, yes, meant 32/36.
32/36 Weber should be cheap enough to find secnd hand.
Here in Australia they were on mid sized sedans, so the wrecking yards are full of them.
I've been told that they aren't too hard to find in America.
Might need an adaptor plate to fit your 20R inlet manifold.
If you can find a second hand 22R-E cheap enough then it should drop in to where the 20R used to be.
Same gearbox and engine mounts.
The wiring of the computer could be challenging but if you also get the donor car's wiring loom then you should be able to figure it out.
It's all in the cost of the second hand parts.
- Stepho
stepho is offline   Reply With Quote
