Re: 1994 Camry V6 oxygen sensor replacement
It should be packed with the part.
The O2 Sensor is replaced in much the same manner as a spark plug. You will
need a special socket wrench (~ $10) to do this job. Some cars have the
sensor in a location that a simple box- or open-end wrench can be used, but
most cars need the special socket wrench.
WARNING
Do not touch the tip of the new sensor or get oil on it.
"Brent" <rbmattis@gmail.com> wrote in message
news:1151170845.914086.183410@y41g2000cwy.googlegroups.com...[color=blue]
> my check engine light came on, code P0135. Needed new oxygen sensor,
> sensor 1 bank 1. So I ordered a replacement from sparkplugs.com, the
> chilton says to use a new gasket, how do i find the part number on that
> gasket so i can order a replacement.
> thanks,
> brent
>[/color]
