2001 Corolla does not accelerate when going on HWY - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-19-2007, 01:29 AM   #1 (permalink)
View corollaBOB's Photo Gallery
Hi Everyone,
I've had my 2001 Corolla for about 2 years.
When i tried to get onto the HWY 5 days ago the car would not accelerate. I pushed the gas down and the engine would simply struggled to get up to speed. I had to ease up and then press evenly just to get up to HWY speeds. That was a nightmare!
I'm out of ideas....my mechanic said it could be bad gas...but went through about 5 tanks so far and replaced the catalytic converter. The only difference is that i now have more power when driving locally.
The problem has not gone away.
Recently replaced:
1) Spark plugs
2) Catalytic Converter
3) Front Rotors + Brake Pads
Any ideas?..i'm stuck.
corollaBOB is offline   Reply With Quote
Old 05-19-2007, 01:58 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
Check airfilter yet? maybe fuel filter too.
Old 05-19-2007, 02:21 PM   #3 (permalink)
Thanks I'm going to get the fuel filter checked. The air filter is pretty new so that looks ok.
Old 05-20-2007, 07:56 PM   #4 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
Is your AC on when you do this?
in my 01 rolla, the AC seems to cut the power by 1/3. more if the recirculate option is going.
Crowbar911 is offline   Reply With Quote
Old 05-20-2007, 08:18 PM   #5 (permalink)
View whatproblems's Photo Gallery
chack your airflow sensor... mine was slightly messed up and would make the car almost stall out after every shift
whatproblems is offline   Reply With Quote
Old 05-20-2007, 08:56 PM   #6 (permalink)
View Revhead Kev's Photo Gallery
Might also be a leak in your throttle gasket or intake manifold gasket causing the MAF to register less airflow than your engine is getting.
Revhead Kev is offline   Reply With Quote
Old 05-20-2007, 11:39 PM   #7 (permalink)
It's a long weekend here, so i'm going to have to wait until Tuesday to get this checked.
Nope. My AC and fan are both off.
So far, I'm going to check the following.
1) fuel filter
2) throttle gasket or intake manifold gasket for a leak
What about doing a fuel system flush? Can that even be solution to such a problem?
Thanks for the replys...can't wait to get back to normal performance.
Old 05-21-2007, 08:32 AM   #8 (permalink)
Crowbar911's Avatar
I have taking my corolla to the toyota dealership before so they could clean the fuel injectors. They told me that 3/4 were totally clogged. (which I find kinda hard to believe that My 4 cylinder engine was working on only 1 cylinder.
It cost me 500 bucks, but it worked great.
Mind you this was at 35,000 miles.
Old 05-21-2007, 09:24 PM   #9 (permalink)
View tech8's Photo Gallery
The fuel filter on the 2001 Corolla is in the fuel tank, and normally does not require service, unless something drastic happened.
You haven't mentioned anything about checking your Mass Air Flow sensor yet. Clean that, and see if it improves your drivability. A dirty MAF will cause hesitation, etc. Just get CRC Mass Air Flow cleaner or Quick Drying Electrical Cleaner. Two phillips screws hold it in the air intake tube, near the air filter. You may have to loosen a 10 mm bolt holding a bracket, which partially blocks the removal of the MAF sensor. Clean the thermistor wires, etc. in the MAF, let it air dry and reinstall. ($5 worth of cleaner, and simple labor.)
BTW: You may want to disconnect the MAF electrical connector first.
tech8 is offline   Reply With Quote
Old 05-22-2007, 06:47 PM   #10 (permalink)
Well i just had the fuel injectors cleaned and performance has increased. There is less hesitation and more overall power. However, still not safe for hwy driving.
Work Done:
1) Spark plugs
4) Fuel injectors cleaned
You're right. I was told the fuel filter is in the gas tank for the 2001. I'm going to have to read up some tutorials on cleaing the Mass Air Flow sensor. Need some diagrams
Things to do:
1) Check Mass Air Flow sensor
2) Check throttle gasket or intake manifold gasket for a leak
Old 05-22-2007, 07:16 PM   #11 (permalink)
View toyomoho's Photo Gallery
Have you checked to see the injectors are getting enough fuel, that the fuel pressure is high enough.
Old 05-25-2007, 02:24 AM   #12 (permalink)
Well i cleaned the mass air flow sensor about 60 minues ago and did a test drive, but no change in performance. I still get no where above 70-80 after pressing down on the gas.
Work Done:
1) Spark plugs
5) Mass air flow sensor cleaned.
Things to do:
1) Check throttle gasket or intake manifold gasket for a leak
2) Check if injectors are getting enough fuel & fuel pressure is high enough
Frustration is setting in..err...going to take it in to the repair shop tomorrow.
Old 05-25-2007, 07:37 AM   #13 (permalink)
Caveman User
triniguy's Avatar
View triniguy's Photo Gallery
I think it could be that your spark plug wires may need changing. Ask an electrician to see if the wires have any cracks that may be causing electicity leaks.
Ask the electrician to check for any other electronic faults eg distributor etc.
triniguy is offline   Reply With Quote
Old 05-25-2007, 11:54 AM   #14 (permalink)
View dgoodhue's Photo Gallery
2001 doesn't have spark plug wires, it has direct coil packs
I haven't done much with these engines computer tuning wise, but in my race truck a bad temp sensor and o2 sensor can really affect performance. A really Dirty air filter as well would kill top end performance. Their might be a way to test the coil packs, but that doesn't seem like they are problematic. I personally don't see the air meter gasket all of sudden going bad if hasn't been touched. How many miles on your engine?
Dave
02 Highlander
dgoodhue is offline   Reply With Quote
Old 05-25-2007, 12:28 PM   #15 (permalink)
CorollaCustomz.com
bzride's Avatar
View bzride's Photo Gallery
I'm not sure why one of the first things you did was change the catalytic convertor.. pretty pricey repair to do if you were just guessing, did your mechanic suggest that?
If the Check engine light is not coming on.. you can rule pretty much anything to do with the fuel system, ignition, and sensors, or emission
You need to do a compression check on your cylinders
Also.. is this an Auto trans? perhaps it's a transmission problem
www.corollacustomz.com
CorollaCustomz founder
Cardomain site: http://www.cardomain.com/id/bzride
bzride is offline   Reply With Quote
History of the Corolla Ratko Corolla Lounge 26 06-16-2010 05:20 AM
Where can you find the radiator plug for 2001 corolla tuyhoa Archived Corolla threads 0 10-03-2006 08:59 PM
Any "angel eyes" for 2001 Corolla 200CorollaS2001 Archived Corolla threads 5 10-18-2005 11:38 PM
