Power Steering Flush - How? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-13-2007, 03:19 PM   #1 (permalink)
Camry, Corolla, Sienna
View SaidiaDude's Photo Gallery
Question Power Steering Flush - How?
I need to flush the Power Steering Fluid from a '98 Corolla, 120K miles (wifey's car). It has the original fluid which is now dark brown and smells. How do I flush/drain this fluid? Is there a bleeder valve like the brake system? I was thinking of removing one of the rubber hoses and draining out most of the reservoir, but I can't find a way to drain the rest of the fluid. Also, I don't want to let air into the system.
Thanks for your help.
SaidiaDude is offline   Reply With Quote
Old 10-13-2007, 08:25 PM   #2 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
one of the hoses is a return line, you could take that off... add a section, using some micky-mouse type fitting, coupler, use the extended hose, run that into a medium size can, or bucket.. and have somone pour new fluid in the pump resivour while you let it pump the fluid into the bucket... but it will have to be coordinated so you don't run it dry, it wil pump it very fast..
actually, you can pull the hose... let the fluid drain.... (engine off). Then pour new fluid in,,, and startt eh engine,, and with the wheels on jackstands tunr the wheel full left and right to purge the air out (if any air) and top it off to wherever the top mark is for the ful line.
This last procedure is the actual procedure in the manual for bleeding air.
Since it's so hard to get to parts in this car,,,, I would suggest you use the bleeders (they are ont he rack steering unti close to where the column and steel lines and hoses connect to the rack. But, if that's to difficult, the try the host connects at the pump.
I suggest you buy line wrenches. They are like open box end wrenches for the bolt on steel fuel and pump lines. They slip over the line but still have 6 pioints to lock around the nuts on lines. They will serve you a lifetime and prevent you from having to use open end wrenches which can round corners.
I would also suggest you ask someone with more experince on pumps ... I have done mine, but there are others here with much more experince with Toyota pumps... maybe they have a better procedure...
retiredat44 is offline   Reply With Quote
Old 10-13-2007, 08:36 PM   #3 (permalink)
mikered30's Avatar
Gameroom cash: $467667
If you don't want to mess around with lines, you could use a less efficient way: use a turkey baster and suck out the fluid. Do that about at least 5 times.
mikered30 is online now   Reply With Quote
Old 10-14-2007, 02:31 PM   #4 (permalink)
Thanks folks. I'm thinking of changing the hoses now. I've changed all the Radiator+Heater hoses (+water pump +thermostat, etc). Is the job similar for Power Steering hoses? I.e. Something like:
- Find a drain bolt or bleed valve as suggested by retiredat44
- Drain fluid
- Remove hoses (how many are there total - 2?)
- Replace hoses
- Refill with new fluid
- Bleed air
Did I miss anything? Thanks
Old 10-14-2007, 10:10 PM   #5 (permalink)
View stubborn1's Photo Gallery
One more vote for the turkey baster method. Actually a vacuum pump works better, but same idea. I remove the old fluid, add new, turn the car on and turn the wheels full rotation a few times to get the fluid moving, rinse and repeat. Usually 3-4 times get the fluid looking new again.
stubborn1 is offline   Reply With Quote
Old 10-15-2007, 05:33 AM   #6 (permalink)
View 94_Rolla_Guy's Photo Gallery
i agree mostly with retiredat44
I have done mine and my GF's simply by taking off the return line to the reservoir then putting a foot long hose on the reservoir so the new fluid doesn't leak out then extend the return line to a bucket then get someone to crank the car and turn steering lock to lock if possible (will empty the reservoir every 30 secs) then shut it down fill and repeat, untill fluid coming out is clean
If you use that clear vinyl hose to go to the bucket it will show you when the fluid is running fresh and clear
when your done put the return hose back then cycle the steering lock to lock top it off if neccesary and call it done
Ah when she was in her glory, Not so nice anymore 358k 17years old her time is getting short ....
94_Rolla_Guy is offline   Reply With Quote
Old 10-15-2007, 06:52 AM   #7 (permalink)
Exclamation
I can't remember the website with the instructions for bleeding the air, but I put it in a nutshell above... you must do that... on stands,,, and it can take up to 1/2 hour.... make sure you have at least a quart, in case you need more.... or spill some...
Do Not run it dry!
2003 Camry Steering Issues nscamry 5th & 6th Generation (2002-2006 & 2007-2011) 81 02-01-2012 12:12 AM
Just a little info I'd like to pass along.. Mr Marv Audio, Video, and Security - Tech 17 01-22-2008 08:49 PM
HELP: Ratcheting Noise in steering column when turning at low speeds... SIrMack 5th & 6th Generation (2002-2006 & 2007-2011) 29 11-14-2007 01:03 AM
Power steering flush mdemeglio T-100 1 08-27-2007 02:52 PM
Power steering run dry - damage? Time to sell? PDXterra Celica Forum 8 01-06-2006 02:05 PM
