Bad Strut-Mount or Coil-Spring? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-25-2007, 03:24 PM   #1 (permalink)
vtd
View vtd's Photo Gallery
I hear banging noise (from front wheel) everytime hitting the pumper, so I jacked the front wheel up and was able to use my hand to push the Coil-Spring up and down a little. That means the coil-spring is bad or the Strut-Mount? (Struts, ball joint and sway bar link have been replaced recently - 1999 Corolla VE).
Thanks.
vtd is offline   Reply With Quote
Old 10-27-2007, 05:13 AM   #2 (permalink)
View Trueno90Deuce's Photo Gallery
maybe the mount isn't bolted down all the way???
Trueno90Deuce is offline   Reply With Quote
Old 10-27-2007, 07:32 AM   #3 (permalink)
retiredat44's Avatar
View retiredat44's Photo Gallery
Exclamation
sure it isn't a bad wheel bearing? Your description isn't enough to to make any determination...
wtf is a pumper.. ?
Don't they teach english any longer?
retiredat44 is offline   Reply With Quote
Old 10-27-2007, 08:21 PM   #4 (permalink)
or more than the mount.... i meant to say, check to make sure that the strut is bolted onto the mount all the way.
Old 12-26-2007, 12:57 PM   #5 (permalink)
vtd
I just got time to replace both of the Strut-Mounts and it fixed the problem, which I should had done when replacing the Struts! Thanks ya'll. Happy holidays.
Old 12-27-2007, 11:21 AM   #6 (permalink)
NoLa Rolla
gaj1967's Avatar
View gaj1967's Photo Gallery
So replacing the mounts fixed the noise problem? I've noticed the same noises and was thinking of replacing the struts but if it's just the mounts it'll save me some $$$.
Gil
gaj1967 is offline   Reply With Quote
Old 12-27-2007, 04:44 PM   #7 (permalink)
vtd
Gil
Yes, it fixed the problem, I don't hear any banging noise anymore.
If your Corolla is over 5 years old and has over 60k miles, you might want to replace the struts as well since you're going to have to open them all up anyway. Those Corolla struts don't last very long, they'll ruin your tires.
I bought 4 Monroe (front & rear) struts for $57 each @ Autozone(the 4th one was free after mail in rebate).
2 front strut mounts for $35 each.
You'll need a spring-compressor, I got one from Sears for $59 (Sears item# 00971466000) (rental tool from AutoZone did not work for me). And BE VERY CAREFUL! when removing the coil springs. Good Luck.
Old 12-27-2007, 07:12 PM   #8 (permalink)
GTChink's Avatar
Gameroom cash: $105050
View GTChink's Photo Gallery
may I ask where did you get the strut mounts from?
thanks
1994 Corolla
GTChink is offline   Reply With Quote
Old 12-27-2007, 08:20 PM   #9 (permalink)
NoLa Rolla
gaj1967's Avatar
thanks
I'm looking at RockAuto.com and they have some various mounts. They also have full strut assemblies with "replacement bearing plate, upper and lower spring isolators, upper spring seat, coil spring (where applicable), boot kit, and a premium Monroe Sensa-Trac® strut" for about $160 each front (for a 98 Corolla that is) if you don't want to deal with removing the spring. I've bought a few things from them with decent service.
btw, thanks vtd for the info.
Gil
Old 12-27-2007, 09:32 PM   #10 (permalink)
GTChink's Avatar
ah cool yeah I know rockauto, good prices.
thanks
1994 Corolla
Old 12-30-2007, 09:18 AM   #11 (permalink)
View crusader8's Photo Gallery
Has anyone used this entire assembly. I need to replace my GF's struts and this seems like a good deal for the whole setup.
crusader8 is offline   Reply With Quote
KYB ( any non OEM ) Strut mount for Gen3 Camry? Front? blueapple 3rd & 4th Generation (1992–1996 & 1997–2001) 2 12-27-2008 12:36 AM
Whiteline; Superpro and Dobinson Group Sale raptorracing Supporting Vendor Sales 222 03-09-2007 06:51 AM
how do you find if strut is bad noltian Archived Corolla threads 14 01-14-2006 01:40 PM
