Cruise for 01 Corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2007, 03:30 PM   #1 (permalink)
G M
View G M's Photo Gallery
Lightbulb Cruise for 01 Corolla
Has anyone gone through the process of adding cruise control to a 01 Corolla? I assume some came from the factory or dealer installed with cruise, that would be the first choice, not really intrested in aftermarket kit info right now unless adding the stock stuff is too labour intensive. What other years of Corollas would the 01 parts be the same as? Thanks in advance for any help.
G M is offline   Reply With Quote
Old 11-12-2007, 10:05 PM   #2 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251221
View REN69's Photo Gallery
1998-2002 is the same basic model, 01/02 models had different headlights and tailights but they were still the same car.
Old 05-14-2008, 03:57 PM   #3 (permalink)
View ttman's Photo Gallery
bump, I want to know the procedure/costs as well.
ttman is offline   Reply With Quote
Old 05-14-2008, 06:01 PM   #4 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $268523
View Buurin's Photo Gallery
Forget the "aftermarket" retrofit path. If I'm doing a retrofit of an option available from factory, I want it as factory as possible.
For cost I'd estimate could run you up to $1k if you get everything from 1sttoyotaparts new. Junkyards will sell for less.
You need to do work in three major areas;
steering wheel (to add the stalk)
behind glove box (to add the cruise control computer)
engine bay (to add the cruise control actuator)
behind passenger fender (to get access to the wire harness so you can hook up the actuator
Depending on your transmission, more work to add a cruise control clutch switch and wire it up (the wiring may already be there) or tap into the "D" wire of your tranny (there's a junction block wrapped up inside the engine wire you can use). This is a safety signal to disengage cruise if you shift out of D or depress the clutch.
Lots of labour, that's for sure.
Little Pig. You are ready.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
77 Corolla and 81 Starlet Questions curtisz Archived Corolla threads 8 03-19-2009 05:25 PM
I Need Your help on a 2003 Corolla LE- unbelievable story Smittay Archived Corolla threads 12 08-05-2006 09:49 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 05:01 PM
adding cruise control to 97 Corolla DX area51 Archived Corolla threads 1 10-01-2004 03:23 PM
