how do i CLEAN the clear plastic of my headlights?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2007, 05:29 PM   #1 (permalink)
View fobdout's Photo Gallery
thanks for the advice! i was looking at the housing again and when i removed the headlight, there was access to the inside of the clear plastic! so i bought a scrubber and tried to scrub off the film that was obstructing the light from passing... even put some dishwashing soap in there... but the film was still there. the weird thing was that when i front part of the clear plastic got wet, it was totally transparent, clear, like i was intending to do when i tried to scrub it. but when you wipe a paper towel to dry off the front, it became opaque again...
i'm thinking that there might have been a clear coating that helped the clear plastic become more translucent?? has anyone ever heard of anything like that before?
fobdout is offline   Reply With Quote
Old 11-12-2007, 05:49 PM   #2 (permalink)
7th Gen Apprentice
View costadragon220's Photo Gallery
It might be from the out side here are some threads relatingto same issuewith good results
Yellow headlights
http://www.toyotanation.com/forum/showthread.php?t=210407&highlight=headlights
costadragon220 is offline   Reply With Quote
Old 11-12-2007, 06:20 PM   #3 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $350545
View Flashmn's Photo Gallery
Might be that the plastic has aged due to the UV and heat radiation from the headlights. Time to get new headlights.
And using a scrubber will scratch the surface of the lens..
Old 11-12-2007, 10:14 PM   #4 (permalink)
ck1uzfeae86's Avatar
View ck1uzfeae86's Photo Gallery
Rubbing compound and an electric buffer, just like paint. It works well for the yellowing on the outside. If you really want to, you can wet sand with some 1500 grit first.
ck1uzfeae86 is offline   Reply With Quote
Old 11-13-2007, 12:43 AM   #5 (permalink)
on full afterburner
PhatRoyale's Avatar
Gameroom cash: $1191747
Meguiars Plastx, works like a charm, you can apply it by hand, let it soak and buff it off with a microfiber while applying some pressure
Old 11-13-2007, 01:35 AM   #6 (permalink)
Vroom?
freakinbox's Avatar
View freakinbox's Photo Gallery
I had used a headlight refinisher kit on my marker lights, wet sand paper and polishing compound is all there, follow instructions and walla. Worked well on the marker lights, and the shop I used to work at had used it on one of their own cars and it came out nice.
I think it was about $18 for the kit (I would get 2 to do the headlights since it's a larger surface) but that sure beats paying (what is it now for headlights?) $150 + a headlight
1989 Corolla sr5, 4af, 1990 gts seats, TRD short shifter.
http://www.cardomain.com/ride/2061750
freakinbox is offline   Reply With Quote
Old 11-13-2007, 12:39 PM   #7 (permalink)
blb
View blb's Photo Gallery
I agree with PhatR. PlastX is good stuff! At $6.00 for a container that will last a lifetime, you can't beat it.
blb is offline   Reply With Quote
Black Tacoma w/ Clear Headlights SR5TaComa24 2nd Generation (2005+) 10 09-14-2007 05:33 PM
clear headlights mdspanky1 2nd Generation (2005+) 16 10-19-2006 09:32 PM
Clean Old/Dirty Headlights to Clear? iarenick 3rd & 4th Generation (1992–1996 & 1997–2001) 8 08-16-2006 04:38 PM
Plastic cleaner for headlights? eeMmwhY Camry & Solara Lounge 4 06-07-2006 10:31 PM
Clear Headlights gen 3? Lyons451 3rd & 4th Generation (1992–1996 & 1997–2001) 7 10-15-2004 03:51 PM
