help with CEL P0171 & P0300 for 2000 Corolla!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-12-2007, 06:49 PM   #1 (permalink)
View palbuddy's Photo Gallery
Codes: P0171 system too lean, and P0300 misfire.
Symptoms:
1. found oil on the spark plug threads(not on the electrodes), all four of them. But no oil was found in the spark plug tubes. Could this be linked to the worn valve cover gasket? Or the oil was pulled into the combustion from underneath(piston, head, etc.) The Oil level drop is noticed, and it is apparent that the engine is burning oil.
2. Poor acceleration: when hit the gas, it takes about 3 seconds for the speed to react. It feels like something is holding and release the tachometer during the 3 seconds. But the speed can go up to 80 mph without any problem. It is just the slow response when pressing the gas pedal.
3. MAF cleaned and checked. This source can be excluded, no improvement.
4. Seafoam was applied through the brake boost hose recently, no improvement.
5. PCV valve replaced, , no improvement.
6. O2 sensor replaced, , no improvement.
Could anyone give me a hint or similar experience? Thanks a bunch!
palbuddy is offline   Reply With Quote
Old 11-12-2007, 07:19 PM   #2 (permalink)
I want to add this:
The ignition is normal when the engine is cold, but it cranks badly after I drive a couple of miles. I found this by trying to ignite right after I shut off the engine after some high-speed drive. The engine cranked like coughing but it finally started.
Symptoms:
Old 03-16-2008, 12:36 PM   #3 (permalink)
View laramarvin's Photo Gallery
You could also check:
 Engine coolant temperature sensor
 Fuel pressure
 Gas leakage in exhaust system
Let me know if this helps.
laramarvin is offline   Reply With Quote
Old 03-16-2008, 04:13 PM   #4 (permalink)
Big T Dizzle fo Rizzle
BigTDogg (MA)'s Avatar
View BigTDogg (MA)'s Photo Gallery
C
Did you spray the red area too? Get it all up in there. That's what cured my P0171
My Vehicles:
2001 Toyota Corolla LE - EBC Ultimax Rotors, HPS pads, Goodridge stainless lines, K&N drop in filter, Magnaflow cat and Exhaust, KYB GR-2, Tein H-Techs
1990 Nissan 300ZX Twin Turbo - More mods than Lindsay Lohan has freckles
BigTDogg (MA) is offline   Reply With Quote
Old 03-17-2008, 09:49 AM   #5 (permalink)
View SBUBandit's Photo Gallery
wouldn't it be nice if you could try new parts like MAF sensors before paying for them. Then you could throw a new MAF on, and if it didn't fix it oh well, give it back. My car has the same problem by the way. I was thinking o2 sensor, but maybe not. Hopefully I will be able to figure it out once I get my new Actron 9190. Hopefully I can see the sensor readings live on it and figure out what is going on
SBUBandit is offline   Reply With Quote
Old 03-17-2008, 09:59 AM   #6 (permalink)
Beware of pigs
Buurin's Avatar
Gameroom cash: $268523
View Buurin's Photo Gallery
P0300 is random misfire. Test the spark plugs. If all plugs fired strong, look at the fuel system.
Buurin is offline   Reply With Quote
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 05:01 PM
P0300 error on 2001 Corolla brianjonk General Discussion 3 07-15-2004 05:14 PM
P0300 error on 2001 Corolla brianjonk Archived Corolla threads 0 07-15-2004 05:08 PM
Corolla XRS!!!! Phi Archived Corolla threads 61 01-09-2004 07:38 PM
Corolla History/Generation Breakdown! Chris Corolla S Archived Corolla threads 8 07-10-2003 01:18 PM
