2002 Corolla Audio Fuse Location - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-15-2007, 10:16 AM   #1 (permalink)
View saucerman's Photo Gallery
I blew the Audio system fuse (I think) this morning when I plugged in an inverter and turned it on. I haven't checked all of the fuses yet, but I've found 3 boxes under the hood. Two are adjacent to the battery, and the 3rd is on the front passenger side of the engine compatment. I did a quick check of the owner's manual and a little more detailed look at the Haynes manual, but neither seems to show the location of specific fuses/relays.
Can anyone help?
Brent
saucerman is offline   Reply With Quote
Old 11-22-2007, 07:39 PM   #2 (permalink)
View iMAC your chic's Photo Gallery
there is no fuse for your audio system.....check the lighter and the dome light it has to be one of those i went threw so much decks.....i blew alot of fuses its behind the storage on the left side of your steering wheel
iMAC your chic is offline   Reply With Quote
Old 11-24-2007, 07:48 PM   #3 (permalink)
View Young James's Photo Gallery
yeah I had the same problem. The dome light is the same fuse. Open the little compartment to the left of the steering wheel, then pull it out and there's more fuses behind that. Check all them too, but chances are, it's the dome fuse
Young James is offline   Reply With Quote
Old 06-30-2010, 05:41 PM   #4 (permalink)
View tarakdas's Photo Gallery
How to pull this compartment ?
Hi,
Any idea how to pull this compartment out without accidentally breaking it: Details please, if you can. I could not find it in the 2004 corolla repair manual floating around in the internet.
tarakdas is offline   Reply With Quote
Old 06-30-2010, 10:28 PM   #5 (permalink)
Crowbar911's Avatar
View Crowbar911's Photo Gallery
pull it out half way, then pull up
Should unclip, and once you get it out, you can see how simple it is to put back.
SCCA First Place 10/25/09. NST
Crowbar911 is offline   Reply With Quote
Old 07-01-2010, 03:23 PM   #6 (permalink)
That works. Thanks!
Bookmark these sites(vast supply of car audio info) cam2Xrunner Audio, Video, and Security - Tech 25 08-10-2010 11:57 AM
2003 Corolla Fuse Box? BostonSEv6 Archived Corolla threads 7 09-17-2006 02:10 AM
corolla 2004 audio system peteriliev Archived Corolla threads 0 12-09-2004 09:43 AM
need audio wiring diagram for corolla 02 notme2 Audio, Video, and Security - Tech 2 10-02-2004 10:44 PM
2002 Corolla tape deck in 2003 Echo louise Audio, Video, and Security - Tech 1 08-05-2004 12:07 AM
