Help with right turn noise/vibration during acceleration
Hi,
Recently I bought a 1998 Corolla. Manual transmission. When I make right turn and accelerating there is a growling noise (like the one from a leaking exhaust) and slight vibrations coming from the front (possibly right). I had it aligned and checked for tie rods/axles/bearings etc.. Everything is OK.
There is lots of noise and heavy vibrations when I drive off with right turn. The more the torque, the noisier. When I do not accelerate, there does not seem to be any noise. When I drive fast even a very slight right turn (while accelerating) seems to generate some noise although no vibrations could be felt.
I changed the wheels and noticed a slight bent on the inner side of the front right wheel. There is also a 2" long whole on the plastic that sits in-between the front right wheel and the engine compartment - looks like the 'wheel of the alternator belt ??' rubbed against that plastic, but not sure about last one.
Could it be that the engine is off-centered, or bad engine/transmission mounts... Any help will be appreciated.
